Results 1 to 10 of 10
Thread: Help needed with ecotec into vr conversion!ASAP!
    VR executive factory manual wagon
    Aug 2011
    The Shire! NSW!
    Exclamation Help needed with ecotec into vr conversion!ASAP!
    Ok this has been covered alot but I'm still confused I have a hole vs auto sedan at home for the motor and wat ever else I need off it to convert it into my manual vr wagon but I need to know a few things.
    #1)what do I have to do to my fly wheel to make it work with the vs ecotec motor?
    #2)can I use my computer to run the motor?(I know there needs to be mods done to loom and motor but what are they exactly)
    #3)do I have to get the security stuff removed off my computer for the motor to run?
    #4)is it possible to have all this running in a weekend with a fully qualified mechanic and me commodore nut lol? I'm sorry I know this is done to death but the more I research the more different every one says to do it! Sorry guys any info would be awesome thanks heaps guys!
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    I don't think you're VR Gearbox will fit upto you're Ecotec motor. Pretty sure VR Manuals use a T5 and the Ecotec use a Getrag.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Some ecotecs had the T5. Think it changed somewhere in the vs model run.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VS UTE, HT MONARO REBUILD
    Dec 2010
    i think series one vs came with T5, later models had the getrag, also instead of modding your existing loom why wouldn't you just take the one from the VS along with the ECU, makes more sense to me but it's your car... but i don't know if the ECU off the VR will work as the VR's had a MAP and a few other little things didn't they? so wouldnt it already be programmed to run a different type of motor?
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    He will need to get an ECU for a VS manual. The VR and VS use 2 totally different motors.
    Aug 2011
    The Shire! NSW!
    Yeah so if I run the computer and loom from the vs and get the bcm removed or the securityremoved off the bs computer everything should work then to a degre till I get the manual memcal put in?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    you can run an ecotec on a 808 has been done before, need to fit up the map sensor and change the coolant sensor for a start then there's some rewiring to do. Also the 808 tune will have to much timing and need to be wound back. If you have a vs pcm and all wiring then that would be easier, can find the thread if your interested.
    Aug 2011
    The Shire! NSW!
    Yeah man well I have a supposed s pack vr that has the conversion done to it but the car has been chopped and shut and is more likely a vs so yeah any help will be awesome dude I just want to make it run and not have to spend big bucks on what should be simple well not so much simple but no over the top complicated does anyone know the computer part numbers for a vs or vr computer? Just so u can double check the computer ay
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    ill send you a link if i find it, for all memcal information and pcm code numbers download the memcal id tool in my sig
    vr x cop
    Nov 2009
    Default can u pm me the link mate
    Quote Originally Posted by The1 View Post
  1. Help with conversion, advice needed ASAP.
    By Benjamin K in forum LSx Development and Modification
    Last Post: 24-08-2009, 10:06 PM
  2. !!help needed asap!!!
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2009, 11:35 PM
  3. serious relationship advise needed asap
    By Eliminator in forum The Pub
    Last Post: 19-03-2009, 07:05 PM
  4. what t peice do i need? help needed asap
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2009, 07:36 AM
  5. Vs gearbox (help needed asap)
    By vs_lover in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 05:59 AM
