Results 1 to 4 of 4
Thread: Coolant reservoir hoses ?
    '94 Holden Calais VR V8
    Jan 2009
    Western Suburbs, Melb
    Default Coolant reservoir hoses ?
    I bought a new battery and in the midst of swapping batteries I realized one of the reservoir hoses from the top of the plastic lid was just hanging and not connected to anything. Wondering if someone could upload a picture or explain where the hoses are meant to go.
    Did a search and looked on the net but no luck so any help would be great!!
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Do a search on 304 engine bays and go to pics, an see what comes up. Jst use google or somthin.
    But, there should only be 2 hoses if we're thinkin of the same thing. the 2 that come off the over flow lid. One is just a drain if the bottle overflows, and the other is from the radiator neck and it should go to the side of the lid that is attached to the tube that goes down into the bottle....if that makes sensce
    Reaper
    Jan 2009
    Thanks ppl, just wasnt sure if one was suppose to go somwhere or just hang as an overflow. thanks again!
  1. vr v6 master cylinder steel hoses to abs module where tyo buy replacement hoses
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2011, 10:56 PM
  2. Brown sludge in coolant reservoir + coolant level dropping
    By phuecn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2010, 08:03 PM
  3. Coolant low in radiator but high in reservoir
    By cams75 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-10-2010, 08:48 PM
  4. where should the coolant reservoir to radiator cap hose sit?
    By joeyd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2010, 11:39 PM
  5. VX L67 - Oil in Coolant & reservoir
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2009, 03:16 PM
