Results 1 to 17 of 17
Thread: vr v6 commo wont start no spark
    VR v6 sedan,vs v6 ute,
    Sep 2010
    south coast
    Default vr v6 commo wont start no spark
    started car it ran for a min then died and wouldnt start so i changed the ecu, changed dfi module,changed coil packs, changed crank angle sensor, changed cam sensor, changed ht leads, still wont start, checked and no spark. fuel pump working fine plenty of fuel. its got me totally stumped, please help
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Does it attempt to turn over?
    Check the negetive wire on the battery terminal.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    Sep 2010
    south coast
    it turns over fine but dont start
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Check the batteries voltage.
    Might not be enough to spark the leads.
    My Commy
    Discuss.
    Sep 2010
    south coast
    vr commo
    Aug 2011
    places
    Sep 2010
    south coast
    Only had the key for 12 months it still activates the central locking and the imobiliser light turns off when the key is on. Im fresh out of ideas and the only thing i can think of that is left is the engine wiring harness. Any ideas????
    vr commo
    Aug 2011
    places
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by shane_3800 View Post
    check imoberliser key might be flat if so you just wasted alot of money
    Would not crank if that was the case..
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Which way are you checking for spark?
    A silly way is to remove a lead from a coil and try and start it lol
    Sep 2010
    south coast
    I am a mechanic!!!! have pulled spark plug out of block and earthed it while cranking it and completely no spark!! The motor will not fire at all! This has me completely and utterly ripping my hair out!!!!!! Can anyone help??????
    vx s pack II
    Jan 2010
    aLKIDA
    Well i am a auto electrician. Did you check the EFI relay?
    Check if there is power getting into the DFI module the power wire would be the red one.
    Also check for continuity from the crank angle sensor to the DFI module there should be no open circuit there. while your checking continuity check from ECU to DFI module
    there are like 4 wires that go from the DFI module back to the ecu make sure there is no open circuit. were all the parts you changed brand new?
    This is considering you checked all the fuses?
    Good luck
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Can you get hold of a scan tool?
    Crank it and look at the live data.
    It has no spark, but does it have an injector pulse?
    vr v6
    Jul 2011
    frankston
  15. #15
    holden vs ute
    Aug 2011
    brisbane
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Quote Originally Posted by Smokinvs View Post
    that sound like could be starters or fuel pump problem?
    If it's cranking, it aint the starter.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
  17. #17
    VP Exec
    Jun 2005
    Might be solved already but...
    A fault that causes no spark on the primary side will also mean no injector pulse and the fuel pump on only initially. This is because the PCM needs to "see" an rpm signal from the DFI before it fires the injectors and keeps the fuel pump running. i.e. check spark first from each of the coils (only one wire is needed because both ends of each coil always fire together).
    There will be spark (normally) without the PCM, BCM or cam sensor. All that is required is the CAS and the DFI, at least one operating coil and that the wiring between them is intact (and a rotating engine).
    There does need to be power to the CAS which is via the DFI. I'd start there, checking for power to the CAS, the earth and that the two signals are switching as the crank is rotated. Jumper wires to power and a test light will do it, made easier with a plug and wires snipped from a wreck.
    Damaged fins on the balancer might also stop the CAS signal.
  1. VL wont start, have spark, have fuel, not cas
    By vlchic in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-01-2011, 09:00 PM
  2. V8 Wont start after Installing new Spark Plug Leads :(
    By commycrew in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2010, 06:45 PM
  3. VS 5 litre UTE wont start (weak spark?)
    By shadow6ix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2010, 04:44 PM
  4. VT SS Cranks but no spark/wont start
    By heyman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2010, 12:35 AM
  5. car wont start no spark
    By sli-rb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-09-2009, 09:10 PM
