Results 1 to 3 of 3
Thread: vs calais odometer not working & heater controls no lights
    vs calais II v6
    Aug 2011
    sydney
    Exclamation vs calais odometer not working & heater controls no lights
    Pls help.
    My odometer does not show up, sometimes it may show 2 little lines where the numbers should be then other times nothing at all.
    And also the display panel for the A/C, heater/ climate control does not illuminate nor does the stereo LCD illuminate, which is a pain. Please Help!!
    VS Berlina
    Mar 2011
    Woodford QLD
    You have the dash with 3 lcd screens right? are they all not showing anything, or just the right hand one (odometer) is dead?
    The A/C panel doesn't illuminate, but does it work? Is everything readable, just not backlit?
    The stereo LCD, the same. Is it readable, just not lit?
    Not knowing a terrible lot about the electronics of the dash cluster, but it seems to me it may be a problem with the cluster. The others, if they work but are just not getting any light, are probably just not getting a signal from the cluster to tell them the lights are on... I assume you have tried the dash lights dimmer too, of course that could turn off the lights to stereo and AC.
    vs calais II v6
    Aug 2011
    sydney
    Default Re: odom & climate control & stereo lights
    Yes it is the one with 3 lcd displays, no none of them are displaying anything, they only light up.
    And the a/c & the stereo does work and yeah it is just the back lighting that isnt working. I have checked the dimmer but nope that isnt the problem.
    I was just wondering if this was a common problem with these models & can anyone suggest an easy fix for this.
    Any info would be greatly appreciated.
    THX.
  1. vs calais v6 heater not working
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:22 PM
  2. !!heater dial lights not working!!!
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-06-2009, 06:16 PM
  3. dash, heater fan lights not working?
    By ianf in forum Electrical Wiring / Questions
    Last Post: 04-12-2007, 07:06 PM
  4. heater not working in vp calais
    By tysons_2001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2007, 05:45 PM
  5. Lights In Heater & Aircon switch's not working
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2006, 08:30 PM
