Results 1 to 4 of 4
Thread: Vats
    VS Executive V8 S speed
    Dec 2009
    Balclutha NZ
    Default Vats
    Hi all,
    Can anyone tell me how to findout if the VATS have been deleted? I have access to a full scanner, and has come up with hotwire condition in the fault codes? I have no idea on the history of the PCM, brought off our ebay equivilant recently and just curious.
    Thanx, Anthony.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    hotwire is bcm code, means the key ring to the keypad hasn't made contact properly, common fault and really nothing to worry about. Just check your keypad contact and the ring to make sure there clean.
    Dec 2009
    Balclutha NZ
    Oh thats probably because the case is broken and the remote sits in the centre consloe most times.
    Does the anti theft system cut fuel pump and all that normally? I only ask as mine only cuts the starter.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    injectors & Starter motor, if the security light is still blinking while your trying to start it then it's still activated.
  1. Vr 5.0 in a vk help !!! Vats memcal error
    By sgtqld00 in forum Tuning
    Last Post: 09-03-2010, 06:36 AM
  2. disabling vats on vx ecotecs?
    By v6rodeo person in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-09-2009, 06:32 PM
  3. Vats?
    By pheobe in forum Electrical Wiring / Questions
    Last Post: 16-02-2004, 06:24 PM
