Results 1 to 3 of 3
Thread: Fuel Problem
    vs equipe
    Aug 2011
    newcastle
    Default Fuel Problem
    Anyone had this problem, my vs is getting spark and everything but wont kick into life, seems as though it isn't getting any fuel through, does it seem as though it's just a fuel pump problem, or something else, any advise would be helpful.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Is the immobiliser light still on when you try to start the car? - it's the flashing red light above the radio.
    Can you hear the fuel pump prime for about 1 second immediately after you turn the ignition on?
    Is you battery fully charged - a slightly flat battery will not start a VS....they will crank but not start.
    vs equipe
    Aug 2011
    newcastle
    Ok cool, you could be spot on about the battery thing, it had lost a little charge due to another problem which i was fixing on the day, thanks mate I'll recharge the battery fully and give it a go, cheers
  1. VB Fuel Pump problem. no fuel getting to engine.
    By Vb paddockbasher in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2010, 09:11 PM
  2. Fuel Problem VZ
    By ufo8mycow in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-11-2010, 09:16 AM
  3. fuel problem
    By brandon17 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2010, 07:38 AM
  4. Fuel / Fuel gauge problem
    By 2ndLook in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2009, 06:50 PM
  5. fuel problem
    By 308commodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2007, 02:35 PM
