hey guys,
my "v6 vs ute 95" seems to be spattering along under load "cruzing in higer gears, highway driving" i have put new fuel pump, fuel filter, plugs, leads and a new airflow meter, everytime i put something new in the car it gets better but she still isnt running like she use to, im outta ideas, can anyone help..
Next thing to try is a new coil pack....or even a secondhand one. Then the DFI module. You usually see the DFI module and coilpacks sold on Ebay as one item. Missing at cruising speeds usually is due to coil problems - what happens is that at cruising speeds the fuel mixture leans out for economy but is harder to fire, so a marginal coil will not fire the plugs under these conditions.
Ok cheers mate. If it is coil packs should it be back firing coughing and farting.
Because thats one thing its not doing. It splatters along sort of just as I accerlate wen cruzing the highway. I have been told fuel but have fix everything to do with fuel I THINK lol![]()
have you ran error code checks?
ok....No how do I go buy doing that
Click here: checking-error-codes-vr-vs-revised
Then refer here IF... you get a code other than 12: fault_codes
The only thing left u haven't touched fuel wise is the pressure regulator.
I'm going with hako on this one, coils. See if u can't swap with a mate just to see if the issue follows the coils
I still reckon coilpacks....like I said before, when cruising the fuel mix is leaned out for economy and this requires a higher voltage from the coils to fire the plug(s)...the higher voltage places extra strain on the coils causing them to break-down and fail to fire the plug especially if the throttle is opened slightly when cruising. Result is the engine misses. Checking error codes may or may not give an indication as high voltage leakage from the coil(s) is not monitored.
ok thanks heps guys think imgoing to go with new coils and dfi,,, willlet u no if troubles keep happening, cheers
