Results 1 to 3 of 3
Thread: VS Equipe high beam problem
    VR
    Jun 2011
    Syd
    Default VS Equipe high beam problem
    I've got a problem with my high beam, it stays on even when it isn't switched on, you can fiddle with it (pull the lever back a bit, sometimes you can get it to sit right but the second you indicate its ####ed again) and it turns off, but overall flashing everyone that goes past while im trying to fix it isn't enjoyable..
    Anyone know how to fix this?
    cheers..
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Just sounds like the whole stalk needs replacing. Just buy a brand new one and replace it man, everyone loves a new stalk
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As above, the indicator stalk needs replacing - this is fairly common. New from Ebay they are about $60, from wreckers about $20.
  1. High beam problem
    By hN! in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-03-2011, 08:08 AM
  2. high beam problem
    By Jezza in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-04-2010, 07:05 PM
  3. High Beam/Parkers work, Low beam doesn't?
    By 003KWK in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2009, 05:15 PM
  4. Common high beam fuse blowing problem?
    By Evman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-05-2006, 08:28 AM
  5. High Beam lights glowing when on low beam ?
    By Madhouse_Dave in forum Electrical Wiring / Questions
    Last Post: 03-09-2005, 10:15 AM
