Results 1 to 3 of 3
Thread: my vs wont start!
    vs ute
    May 2011
    Cooma
    Default my vs wont start!
    hey guys ive got a problem!
    i just replaced the bulbs in my vs ute and when i went to start it again it wouldnt go! it start then stops.
    could this be an error code in the computer which needs fixing?? it has a berlina dash in so it has a digital odomenter.
    please help!
    thanks hah
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    First do a check for error codes: Checking error codes VR/VS (Revised)
    I'd also pull the dash again and check that nothing has been dislodged - try and duplicate exactly what you did. Do not turn ignition on when the dash is removed!....it's best to disconnect the battery every time you play with electrics.
    Check the connections around the back of the ignition keyhole.
    vs ute
    May 2011
    Cooma
    hey mate thanks heaps did the error code thing and came all good thankyou
  1. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  2. VT 5lt wont start please help
    By R8THIS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2010, 06:17 PM
  3. help my vl wont start
    By langen in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-09-2009, 05:24 PM
  4. My VR wont start
    By Commodore_Babe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2009, 11:07 AM
  5. vc - wont start
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2006, 04:35 PM
