THere is plenty of talk in this thread heater core on VS
Its an absolute mission, and if you have air it needs to be degassed and regassed, or else what I have done in the past is cut the pipes by the drivers foot well, remove it, cit the new one to match and some rubber hoses and hose clamps to join it all back up. By far the easier option, I recently replaced mine in my VS, but I didnt have A/C, and needed to do a few other things under the dash, so pulled the lot out, and added A/C lol. Hope this helps a bit.
if you were just looking for cost effectiveness and not a roadworthy issue just join the two heater pipes that go to the firewall together skipping the heater the turn the heater too cold and it will be fine until you have the cash to get it done.... and its a mission some say they have "modified" or bent the heater and swapped them around without removing dash but its unlikely you will do this without damaging the heater core fins or cracking it meaning start again....
I'd be tempted to do the shortcut method at heater core on VS as James39 suggests - there are pics as plenty of good advice there. Pulling the dash is a full days work, plus you know that something will go wrong! The next day you get to put the dash back in.....but the shortcut method really seems simple if you read it and fully understand exactly what you are doing.
Hey bud, I did the shortcut way recently and it is alot easier. My advice is: if you use a grinder to cut out your old core, get a mate to hold a vacuum near the cutting point, otherwise it will look like you've sprinkled glitter in your car and try to cut exactly like you see it the pics, a little bit past the bends and do the clamps up really, really tight. Mine was dripping for a while after I first did it. Might not hurt to smear a bit of gasket sealant over the pipes before sliding the hoses on, don't know if it would do anything but if I did one again I'd prob do that, may help seal it better?
95 VS Berlina
http://forums.justcommodores.com.au/...ml#post1891856
I need some statesman/ calais woodgrain for drivers side panel!!
