Results 1 to 3 of 3
Thread: prob, after reinstalling running gear. pls help
    VR Series 2
    Jul 2011
    NSW Nth Coast
    Default prob, after reinstalling running gear. pls help
    ...... pls help... bought a vr s2 commo for 200. had a few probs... long story cut short , re installed original box and motor after fixing leak in bottom end. got it all fitted up, and tried to start the thing, it windes over but wont start, so i did fault code test, got 13. and 31. o2 sensor and anti theft thingo. well i noticed when i put key in and open acc the red light in the anti theft module still blinks, try to kick over still blinks. i press button on key as i am kickin ova and she stops blinkin, but wont start. pls help
    VS Berlina V6
    Sep 2008
    Turn the key to the accessories and leave it for 45 mins, then try to start it. If it start then could be an issue with your bcm, maybe you knocked a wire or maybe it is a fault with the BCM
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Turning the key to the accessories won't help. You need to turn the key to IGNITION and leave on for at least 45 mins to reset the theft deterrent system. Apparently some VS models need to have their ignition on for two hours to reset.
  1. Gear stick prob
    By SWE11L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2011, 11:04 PM
  2. Rough idle in gear, trans prob??
    By nudge701 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2011, 09:04 AM
  3. [VIC] Vs berlina running gear in rolling shell still running
    By djvass in forum Parts And Other Items For Sale
    Last Post: 29-01-2011, 06:41 AM
  4. VT running gear into VR
    By COO1VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 01:41 PM
  5. Wtb - Vs V8 Running Gear
    By xcesiv in forum Swap / Wanted to Buy / Trade
    Last Post: 06-10-2005, 12:37 AM
