Results 1 to 5 of 5
Thread: Crank Angle Sensor-Fluctuating Idle speed?95 vs ecotec!
    VS 5SPD WAGON
    Mar 2009
    Default Crank Angle Sensor-Fluctuating Idle speed?95 vs ecotec!
    Does anyone know,if ,a faulty cas can cause idle speed to fluctuate dramatically,from say around 800 rpm steady,to around 1500rpm steady ,then sometimes as high as 2000rpm.Ive also had the orange engine light come on and off a few times,and also,sometimes there seems to be a miss under acceleration.For the first 5 or so minute when driving ,the engine seems to nearly cut right out under acceleration followed by misfiring,then everything seems to go ok!Any info would be much appreciated!Cheers ! Oh! forgot to mention that it has also backfired under the bonnet once or twice and that the dfi module was replaced about 15,000 km ago.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check for error codes as the engine light coming on will have left one: Checking error codes VR/VS (Revised)
    I'd also check all vacuum hoses around the throttle body - if one is leaking or is off it will cause these problems.
    VS 5SPD WAGON
    Mar 2009
    Ok ,thankyou,but just to add to my woes,now the engine has started to totally cut out for a split second, under mainly hard acceleration.
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    sounds like TPS to me. Go Check your codes, a monkey could do it with a paper clip.
    THrottle position sensor, as the name suggests measures the position of the throttle and relays the info to the computer. When it croaks you get all kinds of wierd idle problems, jerky erratic acceleration and engine cuts out.... all classic symptoms, its code twenty something from memory.
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
  1. fluctuating idle at highway speed
    By chrisdoesitbetter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-11-2009, 03:53 PM
  2. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  3. VS ecotec crank angle sensor new
    By GMBanisher in forum Parts And Other Items For Sale
    Last Post: 22-03-2008, 02:40 PM
  4. crank angle sensor
    By aurace in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2007, 11:20 PM
  5. Crank Angle Sensor. WHY??
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2004, 08:02 PM
