Results 1 to 4 of 4
Thread: need help car wont start think it's shorting out
    1996 Vs Berlina
    Dec 2010
    narre warren
    Default need help car wont start think it's shorting out
    Long story short I have a VS berlina and when it rains water was leaking into the car so I decided to remove the carpet seeing as it went a bit mouldy and gross, in doing so I broke the electric window switches on the centre console so I've
    taken them out and taped off all the wires so I can replace them later, Also taken out the Amplifier because I want to move it to the boot and taped off all the wires for that too, now when I try and start the car the starter motor sort of coughs
    and then the battery flattens, I assume it's shorting out, at first I thought a bare wire was touching the floor where the carpet used to be but I've taped off everything I can see and unhooked the amp wiring from the battery, it only seems to
    short out when actually trying to start the car and is perfectly fine when the key is on accessories, could it be the starter motor? any way to test it?
    1997 VS COMMODORE,1996 GTS-R COMMODORE
    Feb 2011
    NEWCASTLE
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    how much of the power window wiring did you remove? because the inhibitor switch wiring is right next to the power window wiring.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    1996 Vs Berlina
    Dec 2010
    narre warren
    Turns out the battery terminals weren't connected properly, I sanded the corrosion off them and tightened them up and it works perfectly
  1. car wont start
    By ShawtyNate in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2011, 05:41 PM
  2. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  3. vt wont start
    By Ben. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-04-2011, 09:33 AM
  4. please help my car wont start!
    By caiti in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-07-2010, 10:22 PM
  5. VR headlights shorting out where do I start?
    By chris100889 in forum Electrical Wiring / Questions
    Last Post: 18-01-2008, 07:20 AM
