Results 1 to 8 of 8
Thread: vibration when driving
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Default vibration when driving
    Hi guy's
    just bought the daughter a vr ute and when your driving along it's really noisy as if there is a vibration? but when you corner left in it...all the noise and vibration seems to go?
    any ideas guy's?
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    VY SS
    May 2011
    Auckland
    Check suspension bushes and all the ball joints.
    Is the vibration speed dependent?
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    hi guy's
    it's not wheel balance or alignment i know when those are out, and i really don't think it's a suspension issue?
    it seems more like a wheel bearing? and if i had to make a guess i would nearly say rear left? now if that was the case would the noise go out of it when cornering because the weight is taken off that side more?
    VY SS
    May 2011
    Auckland
    Jack it up. Try turn wheel in direction of camber. Play in this direction is usually a wheel bearing
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Quote Originally Posted by m1lky View Post
    turn in direction of camber? sorry for my ignorance but what do you mean?
    VY SS
    May 2011
    Auckland
    Pull on top of wheel and push in bottom then via versa rocking it backward and forward.
    If theres play there there's a good chance it's a bearing. Unless you can see the control arms moving. If so check your bushes and ball joints.
    While your at it jiggle the wheel in the other direction this usually will show up tierods but wheel alignment should pick that up too
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Does it get worse when you corner right?
    I'm putting my money on a front wheel bearing.
  1. Replies: 33
    Last Post: 09-11-2010, 12:21 PM
  2. VR Vibration
    By mitchoVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2009, 09:04 PM
  3. bad vibration
    By Starkey in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2007, 02:00 PM
  4. VZ Vibration
    By Clinster in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-08-2006, 07:55 PM
  5. Vt vibration
    By satos in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-04-2005, 11:18 PM
