Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By aaronevolution
Thread: Decisions
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Default Decisions
    Okay,
    I need help making a decision.. I want to get 3 different things.
    Pacemaker Extractors.
    Proper Lowering Kit.
    Tinted Windows.
    They are all around the same price range, Im really willing on getting the extractors..But Tinting would be helpful during the summer while I have no air con.
    Lastly My Shocks/ struts and springs has had its day and its almost like driving a tank.
    If you could choose what one you would get? and why?
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    suspention, tint then stractors
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Quote Originally Posted by [jonnoo] View Post
    Any reason you say in that order?
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    suspention cos itll make the ride alot smoother and look better...
    tint second because it doesnt change the feel or ride of the car. but also looks good.
    extractors last cos i think suspention is important and also tint to block the sun can be usefull
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Ah yeah, True Enough :P
    Ill have a think about.. atm Im thinking Tint, Extractors, then Susp.
    Quote Originally Posted by aaronevolution View Post
    I'd get my air con fixed first.
    Well before the bearings become noisey and replaced the belt for a shorter one it didnt activate, it has no gas.. It could cost any where from 50 to 1000... to repair.
    Prefer getting tinted windows..
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Tinted windows will probably only keep your car 4 or 5 degrees cooler than without tinted windows. Air con will keep you at a fresh 18 degrees on those horrible 45 degree days
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    If your suspension needs replacing then do it first. Always fix things before modifying arguably pointless things. You can't build a nice car on a dodgy base.
    If your air-con just needs to be re-gassed then do it as well because that's pretty cheap. Then I'd do tint, then extractors last, unless there's other things you need to fix.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by F l a k View Post
    I know of very few mechanics who will just regas an AC system, seeming how it's illegal.
    The gas only disappears when there's a leak, and you need to find that before you do anything.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Weird, I never knew that. I'd only just got my red P's when I took my car to the local Holden dealership because the air-con wasn't cold and made a weird noise. They said it had to be regassed and that's all that was on the invoice. They put a dye in it and checked it a week later but there was no leaks...haven't had a problem since and it works great.
    Any ideas what went on there lol? (also sorry for being a tiny bit of topic)
    WL Statesman....L67 VS Berlina
    Jan 2009
    Newcastle
    I got no idea where you got your figures from but?
    extractors and susp are around 500 - 700
    but tint is like 300 tops?
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Hmph.. Decisions.. Decisions..
    Might get my Air Con Tested out.. The compressor still needs new bearings..how much is it to get replaced? :\
    Well GunnaBeSumthing..I do believe a decent tint around here is around 300-400.... Not quite the same as prices for Extractors and susp.. but close :\
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Your air con gas runs out faster if you don't use it. I never turn my air con off even in winter.
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Interesting, So If the car wasnt running for a couple of years.. the gas would run out?
  15. #15
    Mar 2008
    That's because the seals dry out as the oil in the refrigerant doesn't circulate and lubricate them, and then it leaks.
    Usually they charge it up with a dye mixed into the gas and check for leaks that way, but usually the leaks disappear after the seals are oiled up again.
  1. decisions decisions decisions..
    By VXjeremy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2011, 07:31 PM
  2. custom plates,,decisions decisions...
    By benjamino in forum The Pub
    Last Post: 08-04-2009, 04:20 PM
  3. decisions, decisions!
    By garfa in forum Car Audio
    Last Post: 13-09-2007, 01:09 AM
  4. SV6 or Calais...decisions, decisions?????
    By Rogues in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-01-2007, 08:07 PM
  5. decisions decisions
    By fourstar82 in forum General
    Last Post: 18-09-2004, 03:08 PM
