Results 1 to 8 of 8
Thread: VS Commodore won't start!
    VS Commodore Utility
    Aug 2011
    Default VS Commodore won't start!
    I have a 98 VS Commodore Ute. Auto with a V6 Ecotec. I've always had a problem when trying to start it. When I turn the key nothing happens. The lights etc comes on and sometimes it makes a whirring noise but nothing else. After a couple of tries it eventually starts. Just recently it's just started splutttering and rumbling for aslong as you turn the key foward but won't kick over. I'm assuming it's just the starter motor and hoping it's nothing more costly and sinister. Any advice or opinions would be appreciated. Cheers.
    VS SS 5L
    Oct 2008
    Kinda hard to work out, coz that sounds like multiple problems... If the starter motor is turning the car over its not your problem, if its throwing out and just spinning and not turning the motor over then it could be a problem. But if its spluttering and rumbling that sounds like its actually turning over so the starter motor is doing its job and the problem is elsewhere.
    When troubleshooting something like that you really just gotta go with the basics, spark air and fuel... If you know its getting those 3 then it gets a bit more complicated.
    WL Caprice
    Mar 2011
    Could be the battery - how old is the battery and is it charged? Get a jump off another vehicle and see if it starts first go. Stick a meter on it, check if the voltage drops as you turn the key.
    Aug 2011
    The sparks and leads were replaced not that long ago. I've tried again and the starter sounds like it's trying to kick it over but it's not starting. When this first happened, I think it actually kicked it over for a few seconds and it sounded sick and irregular and just conked out. I'm starting to think it's not the starter motor
    WL Caprice
    Mar 2011
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Check the negative terminal too!
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Have you done a code check?
    Aug 2011
    So I've stuck a multimeter to the battery and checked all the fuses. I can hear all the fuel gadgets ticking away at the front end of the car but can't hear the fuel pump (behind the seats) doing anything. So my dreaded suspicion is somewhat confirmed being the fuel pump has shit itself. These things are notoriously difficult to replace in VS utes
  1. how to start vr commodore without remote
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2012, 11:13 PM
  2. Help please: VT Commodore won't start
    By sair in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2011, 08:58 PM
  3. V6 Commodore won't start
    By Beno1982 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2010, 08:52 PM
  4. VS Commodore won't start
    By otis33 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2010, 11:44 PM
  5. vr commodore will not start!!
    By richie351 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2010, 12:54 PM
