i have 98 vs ute, and it has recently been reaching high temprature, i had a look under the bonnet and relized the fan wasnt kicking in untill it reach high temp. i was thinking the temp sensor maybe faulty? and was also wondering where abouts i might find the temp sensor?
Since you've a vs v6, you will have both a coolant temp sender, and sensor. They are both located under the thermostat housing at the front of the inlet manifold. The sender (which works the cluster temp gauge) is the small one with one green wire with black plug attached to it. The sensor (which sends engine temp info to the pcm) is the larger one with an electrical plug attached. Its approximately a 19mm hex from memory.
Hope that helps,
Z' Series HSV 297KW 6lt LS2 Conversion For Sale!PM Me For Details
Check your relays first. Thermo (on a VT) will switch on at 102deg i think.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
If its an 8cyl it still on the front on the inlet manifold, but its under the intake and also there is one sender and sensor there.
