Results 1 to 9 of 9
Thread: Stroker block serial numbers
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Default Stroker block serial numbers
    Got a call from a friend who asked what serial numbers (or part of) to look out for when buying a VS 5ltr block as they are factory cleared for a 355 kit. I couldnt help him, so was wondering if anyone could give me the info to pass on.. This will also confirm if the VS SS block I have got is the real deal too....
    Cheers!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    E/N VL649472
    This is in the VS range or 215i engine numbers - this one came from a Grange but not sure if the 215i was the stroker motor.
    If it is your looking for a VL prefix.
    and 3 Dangerous non ABS VN's
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    From what I know, VR series 2 onwards blocks are factory clearanced for a 355 stroker. These blocks also don't say the capacity cast in the side i.e. VR series 1 and older will have "5.0" cast on the side.
    This is info i've had passed onto me so cannot confirm 100% that its correct?
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    The only 5.0ltr blocks that the factory clearanced were the VT Aussie V8's.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Quote Originally Posted by pjdm1980 View Post
    Incorrect.... The VS V8's were also a factory cleared 355 block and I also think the VR GTS had the same in them too. (not 100% about the VR)
    But, the block I have in my garage for my build starts with a "VU"xxxxxxx.... Any Idea whats thats from fellas?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Wrong. All blocks VR onwards. I always thought it was all VR blocks but stand to be corrected if it was series II onwards. I think you are getting confused with the VT (and VSIII) 5 litre roller cam and multi port efi motors.
    VU prefix ran from VN - VS so it could be anything. Grinding a block to suit 355 ci is easy so any good block will do.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Yeah Just a little nic with a die grinder and she's sweet I hear....
    Its only to stop the bolts from hitting I think.. Bugger all to take off really....
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Pretty much as above; I remember when the 348ci 215Kw motors were released (joint venture between Harrop and GMH?) and from then on all factory blocks could run the larger stroke crank.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Reaper
    Huh, well there you go I think you might be onto something there!
  1. [VIC] HOLDEN 304/308 parts: Stroker kit, VN heads, Bored block and more.
    By Blown V6 Hatch in forum Parts And Other Items For Sale
    Last Post: 17-08-2011, 03:06 PM
  2. HP stamped on block where the numbers 308 should be
    By slautr355 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-12-2010, 02:11 PM
  3. chassis & serial numbers vc commodore
    By nathankras in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-03-2010, 10:41 PM
  4. I'm becoming a Serial Killer.
    By Sharoo in forum The Pub
    Last Post: 06-03-2009, 11:38 PM
