Results 1 to 5 of 5
Thread: Castor bar bushes.. The correct way to fit!
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Default Castor bar bushes.. The correct way to fit!
    Recently I replaced many front end bushes and the power steering rack in the ol vs wagon.
    Took it in for a wheel alignment and got a phone call not long after saying the 'castor bar bushes' have been installed the wrong way around...
    This causes the steering not to return as easily as normal to centre position particularly when on full lock.
    So it seems there is two ways to fit these castor bar bushes, and of course stupid me put them in the wrong way and now need to pull it all apart again
    This is the bush that is originally pressed into the crossmember with the big nylex nut.
    Fortunately, the new urethane replacement is a two piece unit requiring no pressing in and out.
    vr v8 calias
    Jul 2011
    victoria
    two piece have you got the right ones your talking about the ones on the k frame which links to the lower control arm its a big round bushwith the big washer at the front then the nut
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Yep, the replacement urethane ones are two piece. One side is a bit larger than the other, and I have them in the wrong way around apparently.
    ve
    Jan 2011
    victoria
    the bigger end should be exposed at the front of the k frame smaller end should be hiding in the k frame
    did them not lol ago got a wheel alignment was fine
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    Cheers 4 that. I currently have them the other way around with the bigger part inside at the back!
    The car drives fine still, but it needs fixing all the same for the third attempt at this wheel alignment.
    Sunday I shall fix it, and it is rebooked for Monday morn..
  1. Vy Castor Rod bushes
    By WestieVYLS1 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-06-2011, 10:43 PM
  2. castor bushes??
    By HoldrodeoLT in forum General Discussion
    Last Post: 13-04-2010, 01:25 PM
  3. castor rod bushes vn
    By xxeppsxx in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2008, 06:55 PM
  4. VY Castor Rod Bushes
    By perthclaret in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-10-2008, 03:41 PM
  5. castor rod bushes
    By deckadi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2006, 05:06 AM
