Results 1 to 4 of 4
Thread: vr central locking not working
    vr v8 calias
    Jul 2011
    victoria
    Default vr central locking not working
    ok my 93 vr central locking isnt working after i bought the car so im trying to get it to work i just bought a new drivers side mechanism the one with the green lug. It locks by hand but one door at a time. You can here the thing trying to work but no response if i do it by hand by grabbing the green lug and pushing up and down you can here it work but the doors dont do anything but when i push it down the drivers side door goes nuts up and down really fast then stops after a few seconds any answers would be great.
    but tomorrow im taking all door trims off and checking to see if there is a bad earth or a connection is off.
    Is there a box that sends the msg to the doors where would i find it so i can check that out.
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    kinda hard to understand what your saying. however...
    confused by a green lug.
    by hand do you mean with a key? as in put the key in and turn to lock or what?
    it could be something as simple as a broken wire (copper not sheath)
    could be the actuator.
    and it all goes back to the BCM, however i know nothing to do with this item.
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    vr v8 calias
    Jul 2011
    victoria
    okay i have taken off all doors trims and had a look at the actuators on all four doors, two were broken so i have replaced them. Then i connected them then tried that, They lock for 1/2 a second then pop up again the key works the same way when i push the button but sometimes then the key wont work at all so im coming to the conclusion that the bcm or body control module as they call it, has had the dick. so my next question is that if i change my BCM do i need to change the key as well? cause if i change it will the car still start without the key being changed to suit the BCM.
    VS Berlina/ KJ Verada
    Sep 2006
    I believe if you change the bcm for a second hand one you need to get the key to match it, or if you buy a new one you'll have to buy a new key and have the key programmed to it.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
  1. vs ute central locking not working?
    By sully1991 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2011, 01:59 AM
  2. Central Locking Not Working
    By MikeCuzzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-03-2011, 06:19 PM
  3. Central locking not working!
    By GIMPY1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-02-2011, 02:56 PM
  4. VP II Central locking not working!
    By sirsmokeallot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2010, 03:26 PM
  5. Central locking not working
    By bhagl1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2008, 08:42 PM
