Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By Reaper
Thread: Twin Throttle Bodies Set up
    VS Executive S2
    Oct 2010
    Central Victoria
    Default Twin Throttle Bodies Set up
    *ECOTEC*
    Hello, i have purchased a Twin throttle body. It has another Throttle body just oppisite the standard one, I was wondering what is the best set up without moving the alternator? I have looked at buying a VN Group A bonnet scoop to give me some more room to play with, but was wondering if there was a Nice and neat way to do so without buying the small scoop?
    Thanks a ton in advice, and if anyone has any pictures of a set up like this i would appreciate it heaps!
    1999 VT
    May 2011
    queensland
    VS Executive S2
    Oct 2010
    Central Victoria
    1999 VT
    May 2011
    queensland
    JustDylan is offline Banned
    VN Berlina
    May 2010
    What? As in the throttle body is on the the other side? Have you got pics?
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    ttb are a waste of money unless you have a high rev 5+ litre. Totally counter productive on a V6 no-matter how wild.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    A throttle body opposit the stock one?
    This seems legit?
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    He means a throttle body next to the throttle body.. I hope. OP we need pics!
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Nah I believe he means on the other side of the plenum, hence the question about the alternator. I've seen this before and it just looks limp. When u see it u'll know what I mean.
    Issue with this setup is there generally there are no baffles to distribute the air evenly to the 1st and 6th runner.
    The bonnet scoop will not help u in this situation only because it is all confined under the bonnet.
    VN Berlina
    May 2010
    If you are determined to do it I rEckon putting the battery in the boot and making a second air box in that location would be the go.
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Just put a ducted scoop on it (you could cut the back off a group A scoop to make a cowl induction scoop) and just run a pod off each side.
    Oh and a mafless tune
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VS Executive S2
    Oct 2010
    Central Victoria
    Thats pic is correct, i would have preferred a mace but seeing they are expensive and not so easy to get. i got the much much cheaper version for now . I am no bogan, Just a kid having some fun with his first car, so what ever f*** ups i make here i will not in the future, Thanks for all the advice. Much appreciated.
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    That setup is a whole bunch of fail. Think of what the airflow will do coming from each throttle body directly opposite each other? It will create so much turbulence and reversion in the plenum it's not funny. And without a proper tune to compensate for the fact that some cylinders will be lean and others bein starved of air it will probably rob power. I'd hazard a guess that it would rob power overall compared to a properly tuned standard manifold as you'll most likely have to fatten up the fuel on each bank (without sequential injection) to counter the detonation in a couple of cylinders meanwhile others will be running rich as because the air isn't evenly distributed.
    I'd sell it and cut your losses.
    Cheap, fast, reliable.....you only get to choose two.
  15. #15
    VX V6 Manual
    Nov 2011
    armadale perth
    Gday mate did u ever did u ever get that throttle body working i just brought one exactly the same was hoping u might have progressed and have some advice ??? would be greatly apprecieated
  16. #16
    VS Executive S2
    Oct 2010
    Central Victoria
    no sorry, i had a chat with someone in aerospace engineering ( they have more of a idea of how air works then i do ), altho car engines isnt his area of expertise he recomended go the MACE style set up, Since it isnt welded i am just waiting to get a day off work to get a extra manifold to set up a MACE style one ( side by side throttle bodies ), In saying this i have a mate who tried this set up and he said he did notice a improvement. Hope that helps regards Damien
  17. #17
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Reaper
    I beg to differ mate. The standard set up on an ecotec leans out cylinders 3 and 4. With a twin tb set up, mace or come, it would be better suited for distributing air. But OPs "twin tb" set up, if the posted picture is correct its utterly hopeless.
  18. #18
    VS S-Pack SII
    May 2008
    Quote Originally Posted by seq4x4 View Post
    I tend to agree here... If you insisted on having a TTB with a throttle body on opposite sides, your best bet would be to stagger them. Such that on the passenger side, you have it towards the front (To feed the front 3 runners) and on the drivers side you have it towards the rear (To feed the rear three runners).
    Then if you're clever enoungh, make a mechanical linkage system to join the TB's.
    This type of setup would be ideal for a twin turbo setup for symmetric looks under the bonnet.
    Although, i would suggest a LOT of tinkering/research into the flow characteristics into each runner!! Maybe like, setup on a flow bench with individual Air Flow Meters on the end of each runner and playing with baffles/deflectors inside the plenum to ensure even/smooth flow into ALL runners.... possibly even make a clear plenum lid for testing only and using some kind of smoke input into the TB's to see any swirling/vortices that generate inside???
    I could go on for hours about this... Would love to make my on TTB for all the reasons above... (I love to tinker) but havent got the facilities at the moment!
  1. Twin Throttle Bodies
    By Drew4692 in forum V8 Development and Modification
    Last Post: 02-10-2007, 07:10 PM
  2. Twin Throttle Bodies 5L
    By JSTPOZN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2007, 04:30 PM
  3. Twin Throttle Bodies On A Vn 3.8
    By tobyduffill in forum Electrical Wiring / Questions
    Last Post: 04-07-2005, 09:11 PM
  4. Twin Throttle Bodies
    By IVICA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-10-2004, 06:39 PM
  5. Twin Throttle Bodies On A Vn 3.8
    By tobyduffill in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-08-2004, 09:12 AM
