Results 1 to 15 of 15
Thread: need help with vs
    vs executive
    Mar 2011
    merimbula
    Default need help with vs
    i was driving and the car just stalled.
    checked the radiator today and it was full but checked it after and there was little liquid in it.
    smoke was comming out of the car.
    has the engine cooked itself?
    iwhat needs to be done to repair it?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    What temp was it on?
    Where was the smoke coming from?
    Will it turn over now its cooled down (maybe seized)?
    If it runs fill it with water and see were it's going.
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Can you provide more info? Surely if its just split a hose you would have noticed the steam coming from the water hiting the exhaust before you cooked it?
    Or has it gone into the engine?
    Have you checked your oil?
    vs executive
    Mar 2011
    merimbula
    smoke was comming from the engine and radiator
    there was a slight tap before it stopped
    havent tried to start it again, going back to the car soon to try and start it
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Was it smoke or steam?
    Check the oil also.
    If you have ran it out of water chances are its burnt all the oil also.
    If this has happened you have probably seized it. Check oil and water and top up both if needed.
    Good luck but by the sounds of it you in a bit of trouble!
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    vs executive
    Mar 2011
    merimbula
    vs executive
    Mar 2011
    merimbula
    got the car started with a ticking noise
    so towed it home
    started it again and the ticking noise was barely there
    could it be the head gasket
    96 VS Wagon
    Mar 2011
    Nth Brisbane
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Check the oil.
    Did you fill it with water when you went and got it?
    You have more than a head gasket issue if it got so hot that it stopped.
    Ticking could be a number of things. First check your oil (that it isnt full of water).
    If Thats ok but you lost all your water i would find where the leak is.
    Running the engine out of water and it stopping has prob stuffed the head also.
    VS commodore wagon V6
    Aug 2011
    Windsor 2765
    Flush the radiator and check all the hoses, then either top the oil up or do a oil change if its over due for one.
    vs executive
    Mar 2011
    merimbula
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
    Well can you find an obvious water leak? Obviously you have driven it without water and when this happens the engine burns the oil/destroys
    the head then will stop.
    2011 Ve clubsport
    Oct 2009
    Wagga Wagga
  15. #15
    vs executive
    Mar 2011
    merimbula
    mange to save it, topped it up with water and oil today
    she starts but i think i need to change the water pump, thermostat and coil pack
    there's not leaks from the engine as well
