Results 1 to 7 of 7
Thread: VR/VS Steering Wheel compatibility
    VH SLE 308
    Jul 2009
    Default VR/VS Steering Wheel compatibility
    I recently bought a replacement steering wheel, secondhand for my VS since the original was 'soggy' to the grip(breaking away from the metal skeleton), but couldn't get ithe new one to fit .
    It Looks the same , as far as the air bag cover being removed goes, because it didn't come with one, but i'm wondering if it is for a VR perhaps and that they might not fit the VS.
    Strange.
    Pics are attached of the "new" steering wheel.
    VR/VS Steering Wheel compatibility-p8241846.jpgVR/VS Steering Wheel compatibility-p8241847.jpg
    Hoping someone can clear this up,, Thanks.
    spud_22's Avatar
    spud_22 is offline Ruled by the P
    95 VS Berlina
    Nov 2010
    Is the hole to big or to small. I had one off a vu looked identical to my vs one but the hole was to big on the wheel.
    3.08 LSD, 1.9.1 High Ratio Rockers, MACE CAI, Spacers
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    I think the VR & VS share the same boss kit so I assume the wheels should be the same. If you need another wheel I have the original one from my VR, it's different to the one pictured.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Steering shaft changed to a larger diameter at VT.
    In the pic there is a 'keystone' shaped hole at the 11 o'clock position. IIRC this is in a different position between VS and VT.
    VH SLE 308
    Jul 2009
    It's been a while since i tried it and i had almost forgotten what the reason was, but yes, i'm sure it was an issue of the spline being a different diameter.
    I will probably have to take it off again and measure the diameter, also i ended up stuffing up the airbag because the warning light is on now and i was confused by how it all fitted in with that wire switch thing.
    Thanks very much for the replies, Another thing to sell on ebay i suppose.
    Is that VR one all 'firm' and the airbag type?
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    It's pretty firm, but it's a non air-bag type, sorry.
    VH SLE 308
    Jul 2009
    Default Diameter of Hole
    OK, Nol worries, thanks but i can't use that oine.
    I have just measured the diameter of the spline shaft hole on this steering wheel and it is 15mm.
    Without taking my other one off the car at the moment, i can't tell you what that is.
  1. Swapping VS Steering Wheel with a VY steering wheel
    By rogerdelmore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2011, 01:34 PM
  2. HSV GTS Steering wheel vs SSV Steering wheel / Re trim ?
    By geo41e in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-12-2010, 04:53 PM
  3. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  4. Power steering pump compatibility VN V8/VN V6
    By Alspos in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2009, 09:20 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
