hey i fitted a cd player to vs exec today and now the fan only blowing on feet, ive checked the black and yellow conectors in drivers foot well and checked the connector on back of switch is on nice and tight...any ideas on what i may have broken or knocked off, first time working on a vs commodore..thanks in advance!
Vacuum line on back of HVAC unit, put it on properly.
Originally Posted by garth
or one of the pipes that direct the air has been knocked off i had the same problem after a stereo install.
ok ill go give those two a go n c how i go...cheers for the propt replys
sorry to sounds dumb mate but where exactly is the hvac?? are you talking the multi connector behind the switch??
ok so ive checked all connectors including the clear one above the cad player and all lines seems to be installed properly...could i have damaged my switch during the install?? funny thing is all the fan speeds work but still blows on feet only..starting to get frustrated..please any vs or vr gurus out there throw me any advice would be greatly appreciated.
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
cheers nathan...where is it located?? still trying to work out how the heck ive dislodged or moved something installing a cd player, done it in many many cars and this time has been a disater!!
My turn for dumb questain have you got the car running while you try the switch?
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
Have a read of this it might help it`s got pics.
The complete VR/VS interior illumination replacement & conversion guide
problem solved thank you very much fellas you saved much swearing and cursing!! now to just fix the drivers door lock and rear struts and my bargin wagon is on the road!!
So what was wrong??????????????
I've got the sane problem as you. What was wrong mate???
