Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By edals
Thread: VS water in oil NEED HELP
    spacattack's Avatar
    spacattack is offline THE ENFORCER!!!
    Custom VN
    Mar 2005
    brissy
    Default VS water in oil NEED HELP
    Hi all, got abit of a drama going on thats confusing the hell out of me so far --
    replaced the inlet manifold gaskets yesterday as mine where buggered ( using the Mace engineering aluminium gaskets ) everything was fine before that, but knew i needed to flush the radiator ( as in most cases broken inlet manifold leads to oil in the radiator as mine has ), so today i drove the car down the end of my driveway to do a flush, for some unknown reason i checked the oil and it was for a better word f**ked, light brown goo would better describe it lol, now,
    could this be a result of a inlet gasket not sitting/sealing right? as said in the manual it only needs 4 dollops of gasket goo in the corners and have confirmed this with a few people
    can this be an extremely good ( or rather bad ) timing and iv done a head gasket?
    again could this be a good/bad timing and the radiator flush i put in yesterday has cleared away something that was blocking a hole in either a head gasket or a water jacket?
    im about ready to give up on this car completely and am at the limits of my wits end, can someone please help, here are some pics first 2 are of the new gaskets iv just taken out, by the looks it looks like it isnt sealing the water in
    Old Gaskets:
    What i drained out:
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    so when you put the new ones on they were all flush, they your torqued the inlet manifold bolts down in the correct sequence?
    1996 VS BT1 SS 5ltr original
    Apr 2008
    make sure you also change the front and back gaskets that you should have got with the mace gasket kit.
    spacattack's Avatar
    Custom VN
    Mar 2005
    brissy
    yup front and rear gasket where replaced to, from what i could see they where sitting all flush, would an unsealed gasket cause this?
    VR v6
    Jan 2011
    perth
    calais
    Feb 2009
    Quote Originally Posted by spacattack View Post
    yes mate, defiantly
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    Quote Originally Posted by shadetreemechanic View Post
    I always thought the aluminium gaskets are for ecotec only...
    i think holden has them for all models now i could be wrong.
    spacattack's Avatar
    Custom VN
    Mar 2005
    brissy
    it is an ecotec
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Did you remember to drain the oil afterwards and go over the bolts twice?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    spacattack's Avatar
    Custom VN
    Mar 2005
    brissy
    had a chat to a few mates about it, few came over to have a look, cant tell if there any damage to the motor itself ( going to flush with oil a few times and see what happens ) but we have come to the conclusion of a few things
    1. 8 of manifold bolts are stretched ( proberbly why doing them up to the torque setting did squat )
    2. going off this pic ( see below ) it looks like the water section was not sealing properly ( due to staining outside the water area )
    so next weekend im going to plaster the f**kers in gasket goo, reinstall them, let them set for a few hours, new manifold bolts and done up to correct torque setting, let sit over night, flush with oil, re-fill, and hope for the best, if not ill be ditching the motor and car for a cheap VS ( $500 or near abouts ) switch over my new suspension, brakes, exhaust and extractors, calais interior and anything else the new VS needs to make a good car and just drive around until the HJ62 arrives lol
    stuntmanmike's Avatar
    stuntmanmike is offline Car wotsit & stuff
    VP 3.8 V6 Auto and VS BT1 5.0
    Jun 2009
    At home on planet earth...
    Yuk! Is there a pin hole somewhere in your inlet manifold that could let water into the valley under the inlet manifold? Maybe a pressure test and detergent...
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Sorry to see this mate.
    I did this to a VR and lucky had no drama, i did not even do the 4 spots of gasket goo as holden said to me its not needed.
    Did you clean all the surfaces etc very well ?
    Did your torque them up from middle in a diagonal pattern ?
    I used GM Gaskets though as i thought they lasted 200k thats pretty good.
    Are the new gaskets warped at all ? and are they seated in the locating lugs ?
    Not saying you did anything wrong just mentioning little things just incase
  1. Mysterious water leak. (water drips from bonnet lever?!?)
    By theragert in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-03-2011, 08:39 PM
  2. vrvs sedan water found in boot how i tested to find where the water was leaking from
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 08:49 PM
  3. Water Temp/Water Pump?
    By Fred 96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2010, 01:58 PM
  4. VX leaking water but water tep guage shows normal ???
    By FIN990 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-11-2009, 12:51 PM
  5. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
