Results 1 to 7 of 7
Thread: VR V6 making a bad rattling noise :(
    VR V6 UTE
    Mar 2010
    Default VR V6 making a bad rattling noise :(
    HHMMM well don't know what to make of it....but the motor is making this weird rattling noise
    and sounds like its either coming from the front of the motor, near the crank shaft pulley and the aircon pump.
    Sounds like something has come loose and is just rattling around, like a stone in a can sound if that helps.
    The car still runs ok just has this god awfull rattle somewhere.
    Any ideas as to what it might be would be muchly appreciated
    Cheers.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Did it randomly go bad? or slowly over time?
    The v6's have a problem with the timing chain tensioner turning to shit, so it could be that.... I know mine doesnt make any rattling noises since I put in a double row timing chain and got rid of the tensioner and balance shaft..
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Remove the serpentine belt and run the engine - if the noise is gone, check each pulley in turn for roughness etc (after stopping engine!). If noise is still there with belt removed then it may well be the timing chain.
    VR V6 UTE
    Mar 2010
    Cheers for the help, it turned out to be the harmonic balancer, put a new one on today and now its all good
    Thanks again for the help.
    VR V6 5spd '93
    Nov 2006
    Southern NSW
    What actually goes wrong with them that it causes it to make that noise? Ive got the same problem atm.
    VR v6
    Jan 2011
    perth
    Harmonic balancer's made partly of rubber, when it splits somehow it makes that loud rattling noise. Easy to spot when it happens
    vr commodore
    Jul 2011
    south australia
    did u chance the sensor behinf the harmonic balance at the same time, coz someti9mes wen pullin off the harmonic balancer u can damage teh sensor behind it
  1. VR exhaust rattling noise
    By taylorsvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2009, 08:44 AM
  2. Rattling engine noise
    By boeing in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-09-2009, 01:47 PM
  3. rattling, grinding, bearing noise
    By TIL52 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2008, 06:59 PM
  4. God almighty rattling noise
    By FREESTYLE_MX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2006, 04:22 PM
  5. rattling noise?
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2005, 10:40 PM
