Results 1 to 17 of 17
Thread: VR S2 fuel in oil?
    VR Series 2
    Jul 2011
    NSW Nth Coast
    Default VR S2 fuel in oil?
    bought this vr on the cheap, and had a few things needed done. any way replaced some parts eg panel , exaust etc and car windes over but dosnt start, any way whilest trying to start it coughs farts smokes and stinks of fuel , checked for leak, NO LEAK decided by matter of inquisitiveness to check oil, and it reaks of fuel...... pls help on possible causes and fixes..... im not wanting to spend to much on this car as its for my partner on her learners, but i do need it to be reliable. (ps) i have a friend wrecking a vr also, so any parts i can get ... any body pls help
    Last edited by bennbeck; 29-08-2011 at 11:43 PM. Reason: really need some help with this one
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    i had a vn that the computer was faulty and caused a injector to be fiering continusly this caused the sump to fill with fue. you may have a computer problem or leaking injectors
    micsnaffled's Avatar
    micsnaffled is offline micsnaffled
    VH 355 V8 5.8litre
    Sep 2005
    South Melbourne
    VS UTE, HT MONARO REBUILD
    Dec 2010
    In Blow by he means that youve got an air and fuel mixture that is blowing past the oil rings on the piston and ending up i the crank case and sump. there is always a small amount of blow by in a perfect working engine but obviously youve got a bad seal or something.
    calais
    Feb 2009
    VR Series 2
    Jul 2011
    NSW Nth Coast
    Default reply:
    the car has 280k on the clock, and it was starting fine until i did the exaust and replaced the bad batt that was in it. i rolled it down the driveway a bit so it was under cover, ever since that it winds over but no start. and fuel smell in oil. just wondering if i replace the injectors, manifold , reg, etc would that help>?
    vs commodore
    Oct 2009
    Tamworth NSW
    As mentioned above,leaking injectors will cause this.You can remove the fuel rail and injectors from the inlet manifold,leaving the fuel hoses connected,and turn on the ignition to pressurise the fuel rail and then check to see if any of the injectors are leaking.You can get brand new injectors on ebay for just a bit more than it costs to get old ones cleaned/recoed..
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by Brett_jjj View Post
    +1 on the leaky injector.
    VR Series 2
    Jul 2011
    NSW Nth Coast
    thanks guys, i do have a friend wrecking the same model car, and i have 1st dibs on anything so i will pull the injectors and rail off of that while im at it....
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by bennbeck View Post
    One would think if it is not starting the unburnt fuel would getting into the oil.
    What did you change on the exaust? maybe you have ripped out the oxgen sensor.........
    VR Series 2
    Jul 2011
    NSW Nth Coast
    i did check the o2 sensor, but it seems fine, and i did do fault code test, and only get the *31 anti theft detterrent signal missing code, which is common on the vr's. got a fuel rail and injectors, with new plugs and coil pack coming on fri, will try those and see how i go. btw, all parts are off a friends car she is wrecking as it wont pass rego due to bent chassis
    VR Series 2
    Jul 2011
    NSW Nth Coast
    might take bcm and key head whie im there. just a q" , will i need any thing off the barrel to use the new bcm and key head?
    1989 vn white
    Jul 2011
    Warranwood, Melbourne
    VR Series 2
    Jul 2011
    NSW Nth Coast
    Quote Originally Posted by rk has a vn View Post
    :O
    All I have to say
    pls elaborate rk, id love any help....
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    You just need to get the BCM and the ignition key fob from the spare car, and you just unscrew the two screws on the old keyfob and remove the metal "key" part, and you then fit this to the other new fob. One thing to look out for is when the metal part of the key is removed from the fob, there is a little metal tab up in the hole the key goes into on the fob, and this tab has to be securely touching the metal part of the key once the key has been screwed to the fob, as this tab is connected to the ciricuit board and completes the earth circuit for the key reader. So just check to make sure the little tab hasnt been bent up or is corroded or dirty,because if it gets a bad connection there, the immobiliser wont disarm properly sometimes and will play up..
    Also is the BCM in the spare car the same level as yours? as theres different levels of BCM fitted to the various models and they cannot be swapped over without a lot of modifications to the wiring looms etc, thats way too much trouble,so check that the numbers on the BCM cover are the same or the type is the same. There are low, mid or high, BCM's available, depending on what options and what equipment level the car was ordered with from new, theres also lux version of the BCM in some cars. You will mostly find that commodore executives will have low BCM's fitted, the acclaims etc usually have a mid level BCM , and calais and statesman have high or lux BCM's fitted.
  16. #16
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Did your read the answer I gave in your other thread: VR S2 fuel in oil? logged 6 minutes before this thread was started?...or was that thread started for another car with similar problems???
  17. #17
    VR Series 2
    Jul 2011
    NSW Nth Coast
    no for some reason the thread linked 2wice. but i had a read and replyed. thanks ppls
  1. blockage in fuel line - appears to be fuel pressure regulator??
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2011, 06:23 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  4. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
