Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By VS Goon
Thread: So, my neautral goes forward and reverse does nothing. Any similar stories or tips?
    VS commodore wagon V6
    Aug 2011
    Windsor 2765
    Default So, my neautral goes forward and reverse does nothing. Any similar stories or tips?
    Pretty much what the title says
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    I think you may need a new box...
    But it goes forward AND reverse? Manual or Auto?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Is your selector plate out of alignment?
    Grab the T-bar and throw it into the lowest gear, push up (wihtout lifting release) until it stops. This should be 'Overdrive D'. Lift the release and shift up 1 spot, this should be 'N', lift release and shit one forward, this should be 'R' one more up is P.
    Do they line up?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Aug 2011
    Windsor 2765
    Quote Originally Posted by Wombles View Post
    Auto, and it's got no reverse at all, the selector is aligned, it moves into all the gears fine and all of them work except reverse, it sounds like its trying to move but the breaks are on, it just slips.
    Okay so from lowest gear (1), to 2 and to 3 and then D without lifting the release, then from R it goes to N then D then 3. They all line up.
    The last thing i done before it broke was A) attempted a burnout, it takes a while to actually go into Drive once i shift it and i revved it too hard before it kicked into drive and it made a large clunking noise (it always done it but it was louder this time due to excessive revving) and B) put about 1 litre of transmission fluid into it
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    u got enough fluid... or too much?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    Aug 2011
    Windsor 2765
    Quote Originally Posted by [jonnoo] View Post
    I'm thinking too much, It was fine until I added about a litre to it about a day before it stuffed up
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Check the level of your auto while running and in park. Also check it's colour. It has to be pink.
    My Commy
    Discuss.
    '97 VS Commodore Wagon
    Jul 2011
    Quote Originally Posted by VS Goon View Post
    I had what you had, my mate tried to move it when my vs was at his place, trans fluid was full to the brim, he shifted it into drive, revved and didn't go anywhere, revved harder and the trans hose to the radiator blew off, here is a picture of the culprit.
    Check that hose if necessary, it's always better to be safe than sorry!
    If I were you start off with changing the fluid out and new filter with gasket, whilst doing that replace that hose and clamps (that way you won't have a massive mess of a few liters of trans fluid all over your feet), then tighten the absolute f*ck outta the clamps and continue with the new filter, gasket and fluid.
    After this is done top her up and try it out.
    Aug 2011
    Windsor 2765
    Done it plenty of times and never comes up too low or too high
    Quote Originally Posted by skappascrap View Post
    I had what you had, my mate tried to move it when my vs was at his place, trans fluid was full to the brim, he shifted it into drive, revved and didn't go anywhere, revved harder and the trans hose to the radiator blew off.
    I'm just gonna change the gearbox as the one in it now always had problems, like slipping and the 1-2 solenoid was gone (code 82 in diagnostic check)
    Cheers for the helps boys
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Convert to manual! Lol.
    My Commy
    Discuss.
    Aug 2011
    Windsor 2765
    I wish! But I doubt i'd find a manual box, they're all damn auto!
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Check ebay.
    My Commy
    Discuss.
    VS S-Pack SII
    May 2008
    you would be shocked how cheap it is to convert to manual... a reco'd auto (changeover) as an auto place is in the vacinity of aroun $2200...
    If you speak to the same auto place... You will find they also service manual transmissions... so chances are, they can source AND swapover your auto to a manual.
    And it probably cost about $1900 - $2000 to convert over, drive in... drive out.
    It all depends if you want a reco'd manual box with 1 - 2 year warranty, or a 2nd hander with a 3month warranty???
    If you have time on your side.... jump on the phone and start asking questions???
    Aug 2011
    Windsor 2765
    Quote Originally Posted by PanthaVS View Post
    I would love to have a manual VS, but I only have my automatic license (I'm 17 and on Red P's) so I'd have to get a new license and stuff like that.
    I already bought a $200 second hand gearbox from a mate (so not 100% sure if it's fully fine but if it's not I'd expect a refund)
    Doing the swap this Saturday (2/09/2011), hopefully will be easier then i hope
    Cheers for the help guys
  15. #15
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    You mean 3-9-11.. :P
    I have an auto licence but drive manuls daily.. :P
    Hope the transfer goes good man!!
    My Commy
    Discuss.
  16. #16
    Aug 2011
    Windsor 2765
    cheers guys, done the swap and am very happy with the outcome
    I never knew how terrible the old gearbox was.. for once I have 1st gear!
  1. Replies: 41
    Last Post: 14-07-2008, 05:26 PM
  2. Rolling Forward in Reverse
    By Lindsayr in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-10-2007, 09:34 AM
  3. reverse park tips
    By r_i_d_a_h in forum The Pub
    Last Post: 06-03-2007, 09:19 PM
  4. old VL stories
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-12-2005, 07:28 AM
  5. Cat Stories
    By Pretender in forum General
    Last Post: 31-10-2005, 12:12 PM
