Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Like Tree1Likes
Thread: No fire in the hole!!!!
    vs executive
    Aug 2011
    broken hill
    Default No fire in the hole!!!!
    I really love my vs v6, so much so that right now i actually feel heart-broken and lost. I brought jess (my vs) three and a half months ago, she came with 260,000 km's on the clock so i drive nice and easy, practically i wet nurse her. Last friday things went south, i'd been driving jess for about an hour and everything's all good. I pull up at the shop and turn her off, i come back out start her and as i drive off i feel a real sluggish and un-responsive motor then next minute jess dies! Try to start her again and she just coughs and farts and dies again. I've swapped out the coil packs and had a new crank angle sensor fitted but still no starting. What the hells goin on with my car, please any advice or help would be very greatly appreciated.
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Hows the fuel? When did the filteer get changed?
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    vs executive
    Aug 2011
    broken hill
    Im guessing the fuel is good, not sure what the condition of the fuel filter is. Thought maybe the fuel pump but when i leave jess overnight she'll start for me in the morning and run for about half hour then when i turn her off she refuses to start again. Can the fuel pump just pack it in then go good again the next morning?
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    When the fuel pump died in mine it just wouldn't go again at all. Checked the ignition leads? Battery voltage? I'm not really sure what could cause it, sorry.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    vs executive
    Aug 2011
    broken hill
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Let's start with the simple things, check ur error codes, to see if anything has been logged.. We may have something to work from.. If nothing, we go from there..
    vs executive
    Aug 2011
    broken hill
    If i check for error codes will that delete any memory? Just thinking incase i eventually need to take it to a dealer for repairs.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Nar, checking codes is exactly that, checking. if u disconnect the battery, that will clear the codes, which u may need to do if something is logged and the issue is then resolved. U clear the codes to make sure that issue is fixed and not still logging codes
    vs executive
    Aug 2011
    broken hill
    Car has been to the mechanic, he got it to fire but after running it for 15 mins turned it off and wouldn't fire again, just cranking. If i leave the car and come back to it after a few hours it starts but after running it a while and turning it off its hard to start again, it fires up only to run a few seconds sounding like crap and stalling. Car is going into the holden dealers tomorrow and hopefully they can fix her.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    I'm thinking, possible loom issue, heat is causing massive resistance, affecting coil packs/dfi module.
    Any error codes?
    vs executive
    Aug 2011
    broken hill
    Didnt check for codes, im not that flash mechanic wise so i left it. A dude at the garage reckons it may have something to do with the MAP sensor??? Will find out codes tomorrow and see if the dealer mechanic is worth he's salt. cheers mate
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    vs executive
    Aug 2011
    broken hill
    Wombles's Avatar
    1995 VS Acclaim
    Oct 2009
    Its supposed to be MAF.
    My Commy
    Discuss.
  16. #16
    VS Berlina/ KJ Verada
    Sep 2006
    Holden are going to rape you...
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
  17. #17
    V6 VR Acclaim
    Jun 2010
    Quote Originally Posted by SWE11L View Post
    Not true all the time.. The Holden dealer in my town is actually cheaper than all of the other mechanics around. This happened to my brothers car awhile back, turned out to be the MAF sensor as well. But his car had too many problems to start with, so it may not be that for you.
  18. #18
    Sep 2006
    Quote Originally Posted by Bourbonated View Post
    Good to know, I wish they were all like that. I took my VL and VS to one here in Sydney years ago and for the VL they tried charging me more than what I paid for the car (which was a decent price back in 99) and put in the wrong injectors and tried to charge me twice for labour! A few years later thinking I was doing the right thing I took the VS in when I first got it and walked out $2500 poorer, never again!
    Sorry I don't have any useful info for you roces
    95 VS Berlina
  19. #19
    vs executive
    Aug 2011
    broken hill
    Well im not sure what the mechanics on about then. Tryin to dribble something about a MAP sensor and this bloke is charging me $125 an hour labour to try an fix me car!
  20. #20
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by roces View Post
    Good luck with the car mate, but its really not a good move to get work on a VS done at a holden dealer. Most local mechanics will charge 50% less on labour, less on parts, and often have more experience fixing common issues on older cars like our beloved commys. I think Holden dealers charge a rediculous amount for hours of diagnostic work which a better mechanic could diagnose in 2 seconds. The fact that he's waffling on about a MAP sensor sorta confirms this
  21. #21
    vs executive
    Aug 2011
    broken hill
    Thanks monkey. Its bull mate i tell ya, 2 holden mechanics lookin at it this morning and between both of em' they cant figure out whats goin on. Even now my car starts and runs for 30 mins but as soon as i turn it off it wont start again, just cranking. The holden dealer quoted me 3 hours labour at $125 an hour to replace the fuel pump (which they suspect it is, on account of only registering 10 psi on the fuel line while car is cranking) but stuff their labour costs, i dont have a spare $375 to pay em'. Im gunna try and replace the pump me-self, im just really hoping it is the fuel pump causing all this strife.
  22. #22
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    roces, now is a good time to check your error codes to see if anything has been logged. yes i keep going on about it but is so easy to do.
    did they plug in a device in the cabin? i would hope Holden did a check..
  23. #23
    vs executive
    Aug 2011
    broken hill
    Yeah ephect the holden mechanic checked for error codes but none registered. So with no codes to go on im pre stuffed. The holden dude said a buggered fuel pump wont show up when checking for codes. Is that true?
  24. #24
    VS Stato l67
    Mar 2009
    Melb
    Look mate, ive never changed a fuel pump but ive changed a diff in a VS and spent a couple hours with my head next to the fuel pump. I would say that there is no way in hell a fuel pump take 3 hours for a mechanic with a hoist to change. Id be shocked if it took an hour.
    Please anyone feel free to correct me if im wrong
  25. #25
    V6 VR Acclaim
    Jun 2010
    This is true. If you are going to change it yourself, I must stress to you the importance of the hose inside the tank that runs into the swell pot.. Make sure you have something holding onto this while you are doing your pump replacement so it doesn't fall back inside the tank, if it does you'll be up shit creek. If you aren't really confident in attempting it yourself, you are probably better off getting somebody to do it for you.
    Quote Originally Posted by monkeys437 View Post
    It took me 4 hours in a car park with only my scissor jack to do mine.. So 3 hours on a hoist is complete bullshit.
  1. VH won't fire. - Need help BAD!!
    By Lewie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-05-2010, 12:32 PM
  2. help with vn 5.0 no fire
    By kid383 in forum V8 Development and Modification
    Last Post: 15-05-2010, 12:25 AM
  3. Fire!
    By jakbob in forum Photography
    Last Post: 18-02-2010, 01:23 PM
  4. vz on FIRE!
    By ohmygodmyvz.... in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-04-2009, 05:43 PM
  5. VT on Fire
    By nugatory in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2007, 10:04 PM
