Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By lznger88
Thread: VS Acclaim Low Idle (Automatic)
    VS Acclaim
    Aug 2011
    Australia
    Default VS Acclaim Low Idle (Automatic)
    Hey all,
    I have a 96 VS Acclaim automatic and recently have encountered a low idling problem. It seems to idle fine in park or neutral, but when I change gear to reverse or drive, the car will idle very low causing it to shake and then jerk into gear or even stall. Even while at a complete stop the car will idle low. Has anyone had a similar problem, I couldn't find a post similar or maybe I didn't look hard enough.
    Thanks
    Holden Commodore Acclaim VS 96
    Serviced every 10,00kms
    165000 kms
    VS Berlina/ KJ Verada
    Sep 2006
    Mine was doing this untill I changed the inlet manifold gaskets and now it doesn't. Not saying this is your problem too but could be somewhere to start.
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    VS Acclaim
    Aug 2011
    Australia
    Thanks Swe11l,
    That's the problem I have, I'm not sure where to start at the moment. Was hoping to find people who have had the same problem, as yourself, to give me some ideas. It's at the point now where I'm willing to try what others have..
    VS commodore wagon V6
    Aug 2011
    Windsor 2765
    Could be a serious gearbox problem, mine done the same thing and would 'clunk' into gears, turns out the 1-2 solenoid was shot
    VS Acclaim
    Aug 2011
    Australia
    Mine actually also 'clunks' into gears, more so when changing to drive...... :S
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    I had my car checked over by holdens and they didnt seem to see anything wrong with it..
    but like I can go into gear from N or P and its fine.. but if I reversing and started to turn the wheel and put it in drive it would sometime stall.. I think the sudden clunk jerks it and causes the stalling.. but Id say its transmission/diff related..
    VS S Pack
    Sep 2009
    it could also be your IAC motor as this is what does the same job as the idle screw on a carby - try taking it off and cleaning both it and the area it fits into as they tend to build up with carbon and cause idling probems as well
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Quote Originally Posted by Trikky View Post
    hmm, Holdens cleaned out my throttle body.. almost felt the same when I got it back..
    VS Acclaim
    Aug 2011
    Australia
    Thanks Guys,
    Ill start with the cleaning of the throttle body and IAC and see how i go, hoping it fixes the low idle. But the gear 'clunk' change is still a concern
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Cleaning will help if its badly clogged up to start with, but a good place to start. ( just don't mess with the TPS which is also on the throttle body ).
    Few other long shots ... is your AC permanently on ? how is your power steering ? you said that turning the wheel makes it worse ...
  1. [SA] VP SS - Automatic - $5500
    By Dan355 in forum Vehicles For Sale
    Last Post: 23-04-2011, 03:13 PM
  2. VT V6 automatic problem.
    By XR-Lane in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-10-2010, 02:47 PM
  3. idle problems. won't sit at a constant idle.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 07:59 PM
  4. Automatic hanging in first
    By mat vsII in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-08-2009, 12:06 PM
  5. Automatic Gearbox
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2004, 10:57 PM
