Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By nathanVY
  • 1 Post By PanthaVS
Thread: VR V6 SHOCKING noise (With Video)
    304runner's Avatar
    304runner is online now ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Default VR V6 SHOCKING noise (With Video)
    A mates car turned up today and it sounded like a spanner was floating around in the bell-housing....
    Its a VR v6 Auto.
    Any idea whats gone wrong with it?
    :CAUTION: It may make you cry....
    http://www.youtube.com/watch?v=NCj3qsFcXek
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Well sounds like something it clipping metal to metal, but no clue what it is lol im sure someone else would have a idea.
    vyss
    Jun 2011
    vic
    it is very hard to tell from the video but you say its comming from the bell housing. id take off that lower cover plate and see if anything falls out, it almost sounds like a bolt is rattling around as it hits the flexplate.
    VR Calais
    Mar 2011
    Plumpton
    Have you tried feeling where the nocking noise is coming from? Usually that's a easier way to find where it is
    1993 VR CALAIS 5 SPEED MANUAL,Lowered all around on pedders, 20 inch G8s, Option audio front splits, option audio amps, sound stream subs, pace maker extractors, high flow cat, 2.5inch lukey cat back exhaust
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Yeah its coming from what ever cover (has a little hole in it) is just bellow the bellhousing... I'll get him back over and have a look tomoz
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The VN/VP used to crack flexplates pretty commonly but its not unheard of in VRs, chances are its done just that.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    So I got him back over last night and unbolted the inspection plate (or what ever they call it in an auto) and could see nothing....
    He started it for me when I was under it and it sounds like its coming from the torque converter?
    Flex plate looked fine, either way it looks like my weekend will consist of splitting the box and engine and having a closer look
    VS S-Pack SII
    May 2008
    the torque convertor is full of fluid... it wont have anything in it to "rattle" as you described...
    Before you go crazy and split the engine from the tranny... are you sure it's not something in the sump?
    You would be AMAZED how sounds can travel through an engine... like suggested by WPN38L ... feel, not listen for the noise... have you tried touching the sump?
    Another idea, Use a big flat screwdriver as a stethoscope... pressing the handle onto your ear (so it closes your ear with that little flappy bit at the front of your ear hole)
    just my 2c ... hope it helps!
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Quote Originally Posted by PanthaVS View Post
    Yeah I got a home made stethoscope in the garage, Its just a bolt ground down to a point with a bit of garden hose attached to it. It works well...lol
    I'll try that one and make sure its not coming from anywhere else...
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Hey man I had this problem with my VS (the sound didn't work on your video but assuming it sounds like your car is possessed) a few months ago.
    Everyone said, flex plate bolts, starter motor etc. Replaced the starter motor, complete waste of money there was nothing wrong with it.
    Its likely to be the pump in the auto thats given up on life... I'd just sus a 2nd hand box thats what I did. Get it out asap as it's likely putting metal shavings through your trans and when you get it changed MAKE SURE THEY FLUSH THE RADIATOR AND TRANS LINES out completely or there will be metal shards in your new trans
    good luck!
    VS S-Pack SII
    May 2008
    Good point nathanVS ... can check that easily too by droppin the auto pan... metal shaving/sludge on the magnetic pickup = stuffed pump in the tranny?
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Yeah i'm not exactly sure how you'd tell for me it was a case of, waste $100-200 getting someone to check (trans fluid is expensive + overcharged ) or just getting a new trans and knowing it would work.
    I picked up a reco trans for $150 so stoked !!!!!!!
    VS S-Pack SII
    May 2008
    Quote Originally Posted by nathanVS View Post
    Fark... for that price... why not! :P
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    So good! and a race trans cooler for $35! Still cost 450-500 to get it put in but beats 2 grand!
  16. #16
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Turn your speakers on
  17. #17
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    They were on I swear O_o
    Edit: Hmm working now. sounds a bit different to what I had, mine was more consistent grinding.
  1. LS1 LOUD knocking noise with Video
    By 304runner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2011, 04:43 PM
  2. 95 VS V6 Knocking Noise (With video)
    By Excale in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2011, 12:30 PM
  3. Help! Ticking Noise Video On LS1
    By johnno010684 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2011, 09:48 PM
  4. Vr Statesman annoying noise (With video)
    By ethann in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2010, 08:51 AM
  5. Strange SV6 Engine noise (with video) - please help
    By thebulk in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-09-2009, 10:39 AM
