Results 1 to 15 of 15
Thread: Another Problem :( Still Won't Start...
    VS Commodore 3.8L
    Feb 2010
    Thumbs down Another Problem :( Still Won't Start... (VIDEO)
    Started with my car not being able to start every time when I turned the key, Didn't really care because it started eventually.
    Then one day it didn't start at all, like the battery was completely dead. Charged it over night, still dead.
    Went to K-mart bought a battery, seemed to start fine, except this time my sub in the boot wasn't working.
    Yesterday morning I went to start my car and nothing, and this is the new battery. Charged it over night and still nothing this morning.
    I'm assuming this has something to do with the starter motor now?
    Any ideas/suggestions??
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    does it or did it make a tick sort of sounds when it didnt start?
    does it start if you lock the car then unlock the car then try to start it?
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    VS Commodore 3.8L
    Feb 2010
    Yea it made a ticking sound when I tried to start it, which eventually got slower the more times I tried it
    And I unlocked it this morning after I hooked the battery up and still nothing
    Feb 2009
    longford, victoria
    my guess is the starter motors shot, its probably actually just the solenoid but your best to just replace the whole assembly. i replaced my starter recently for the same reason. it cost me about $140 for the replacement starter
    my geminis
    96 VS SII 5.0 Calais
    Apr 2009
    Melburn
    Check your boot or interior lights arnt staying on. Something may be running that you arnt aware of every time you lock the car.
    VB SL/E
    Dec 2008
    Feb 2009
    longford, victoria
    agreed^check you dont have something running constantly draining your battery. check your battery with a multi meter.
    my geminis
    VS Commodore 3.8L
    Feb 2010
    Thing is though, i charged the battery overnight then stuck it straight in in the morning, and still nothing, even if there was something draining it constantly it wouldnt have mattered for the battery went in
    VS Commodore 3.8L
    Feb 2010
    VB SL/E
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The sound the solenoid is making is the same you get from a virtually flat battery OR dirty and/or loose battery connections. Check all connections which must be tight and clean....also check to see if they get hot when you try to start (indicates high resistance). Some batterys don't like being cranked for a long period and will fail even if new....also charging overnight with a small charger may not recharge the battery enough.
    A good check if you have a bad battery is to turn the headlights on - try and start the car - if the lights are yellow without starting the car the battery is flat, and if they go yellow when trying to start then the battery is partially flay. They should stay reasonable bright if the battery has good capacity and all connections are good.
    VS Commodore 3.8L
    Feb 2010
    Cool
    cheers hako
    turned out to just be a loose connection i think.
    wriggled around some wires at the starter motor, gave the battery terminals the best tightening they have probably ever had. And low and behold, it purred into life.
    narrrceeee
    Feb 2009
    longford, victoria
    Quote Originally Posted by Kierab View Post
    cheers hako
    narrrceeee
    i remember a mate had a problem with his where the wire from the battery to the starter rubbed through and was shorting out, might be worth checking.
    my geminis
    VS Commodore 3.8L
    Feb 2010
    Quote Originally Posted by nemesis_adrasteia View Post
    ahk, ill have a look at it, probs selling the car soon, need to fix these things so it starts when they come
  15. #15
    vr 5 litre
    Dec 2011
    Bunbury
    i had the same problem on my VY i foud out about it by getting myself zaped i soon replaced the cable
  1. VX SS start up problem.
    By scvs6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2011, 07:40 PM
  2. Start-up problem
    By PorkoWog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2010, 12:02 AM
  3. VT2 Start Problem
    By griskwat in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-04-2009, 09:15 AM
  4. problem on start up
    By seans VL Calais in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-05-2008, 10:19 AM
  5. vr.start problem
    By deckadi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-01-2007, 09:30 PM
