Results 1 to 6 of 6
Thread: Rear bearing noise?
    VR Executive S 3.8
    Oct 2007
    Default Rear bearing noise?
    Hi guys!
    Lately I've noticed a noise comming from the back end of my VR commodore (live axle), sounding very similar to the front end noise when my front bearings needed replacing. It sounds like a low pulsation (like I said, similar to the front bearing noise, but the noise does not change when I change the steering direction). I hear it at slow speed, maybe around 40km/hr and less. Its especially evident when braking at low speed, and I even can feel the pulsation comming though my brake pedal. I guess that it could also be a warped brake disk, but I changed them all about 18 months ago. My car has 300k on the clock. Any ideas?
    1998 vs s3 ute
    Jul 2009
    near blacktown
    ive got a weird noise at the back of my ute every time i take off from the lights sounds like the diff clunks back and driving under 40kmh rear passenger side wheel sounds like a trailer and when i put the brakes on at low speed it makes a big clunk noise and im lost dont know what it is i was thinking maybe bearings for the trailer noise all the brake rotors have been changed and all the bushes any help much apreciated
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the uni joints, especially the rear one. A bad uni will make a whirring noise before failing completely.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    VR BT1 V8
    Jan 2009
    Geelong vic
    If the noise does not change when the wheel is loaded and unloaded its normally not a wheel bearing. Also wheel bearing noise gets worse with speed. Since the noise gets worse with brakes indicates noisy tyres, check the condition of your tyres even if you rotate them you should find your noise goes to the front.
    1998 vs s3 ute
    Jul 2009
    near blacktown
    its not like a tire noise more of a brake noise or apply brakes and its like a loud thumping noise
    but ill give it a go
  1. vs rear wheel bearing noise
    By vsbt1sa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2009, 08:40 AM
  2. Rear wheel bearing noise from my VT sedan
    By HoldenHaven in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2009, 05:38 PM
  3. VT Front Bearing Noise
    By SteveB62 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2008, 02:09 PM
  4. bearing noise
    By homer simpson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2007, 04:00 PM
  5. Bearing noise V8
    By tollmeyer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2006, 09:28 PM
