Code 31 - Theft Deterrent Signal missing - What would cause this?
Ive had a look on the forums and people say faulty key?
I've disconnected the flashing light in my dashboard.. would this have caused the code?
I went to start it yesterday.. nothing.. took key out and tried again and started up... - or maybe this?
Also.. Since Ive got my car back from Engine Transplant it sometimes flashes the yellow engine warning light? while driving..
cheers
if yo are getting the check engine light best checking the errors codes as per Checking error codes VR/VS (Revised)
I've done error check.. and got Code 31 - Theft Deterrent Signal missing.
It's not unusual to get a code 31 for no apparent reason so I wouldn't be concerned unless you are having difficulties starting the car. I'd reconnect the flashing red light as it is a good indication that the immobiliser is ON/OFF.
