Results 1 to 5 of 5
Thread: hard to start
    VR Calais
    Jan 2009
    Cool hard to start
    Hi, Could someone please help me I am having trouble starting my vr. when i try to start it takes about 15 seconds to start then idles poor and blows a little smoke for a few seconds then runs ok after that I have replaced the plugs,leads,fuel filter and air filter. sometimes i can hear the fuel pump prime and other times i can't I have checked error codes and all is ok how do I know for sure it is the fuel pump and if it is how do i replace it. Also how do i check the fuel regulator and where is it ?
    Thanks guys
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Run an injector cleaner through? Change the battery if its old as it may just get enough volts.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    304runner's Avatar
    304runner is online now ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Sounds like what happened to my car when I put that E10 crap in my tank...
    vs executive
    Aug 2011
    broken hill
    A faulty fuel pump won't register any codes, only way i know how to check the pump is to pressure test your fuel lines, should be registering around 30psi before the injector rail and you won't hear the fuel pump whir once the lines are primed. Cant really help with the start-up issues, maybe try replacing the coil packs.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Sounds like its flooding from either dribbling injectors or leaking fuel pressure reg , remove the vacum hose from the reg and check for signs of petrol in the tube , leave the hose off for an hour or so then try restarting your car if problem still continues then have your injectors cleaned or replaced
  1. hard to start
    By sutto in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2011, 11:17 AM
  2. VR hard to start
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-03-2011, 10:24 AM
  3. VT is hard to start
    By grassy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-09-2006, 08:41 PM
  4. hard to start!!!
    By dahlyla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 02:24 PM
  5. vn hard to start
    By stilly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2005, 09:38 AM
