I was just wondering is it possible to put a VT interior ( Seats ) into a VS??
1999 VT Series II Executive 3.8 Ltr V6
yes.......
Power is measured in DECIBEL
Front seats aren't too bad to do, you can put the VS seat rails onto the VT front seats, or modify the VT rails. Back seats are a bit harder, as you have to bend stuff to get them to fit right.
Have a search, I think there was a detailed writeup on this.
there is a good write up on doing this in the howto section, to keep it legal you need to change the base from your VS seats onto the VT seats - you loose the power fuctions of the drivers seat though and the rear seat you need to make two plates to mount the outer back rests and the base you change the wire frame
First seat will take you ages but the second one is not that hard, well worth the effort if you get some nice VT seats
Yes , easy to do man . Done it in my cars
Is a VT/VX seat conversion the same for a VR as it is for a VS?
Hm ok thanksIm going to say yes as I had vr calais seats in my vs once and was a straight fit so , vt seats modified for vs should fit vr easy![]()
