Results 1 to 6 of 6
Thread: VS Calais/Statesman dash calibration issue???
    VS
    Feb 2011
    Newcastle
    Default VS Calais/Statesman dash calibration issue???
    I have a Calais/Statesman instrument cluster in my VS.
    Stopped at the servo and hit the "SET" button whilst the speedo was displayed and it showed me that there was -2.0l in my tank.I adjusted it so that it read 0.0l in the tank.
    I put 50l of fuel in it and before i got in the car i turned ignition on and hit "SET" again and it showed 66.7 litres.
    SO my question is, how can i calibrate the digital section of the dash to read correctly in regards to this?
    What does the flocal of 625 mean?
    Thanks in advance
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Flow 625 is the stock setting for the ECU cals for instant fuel at DTE.
    The tank calibration should be done on level ground and when the tank is full. Most roads and driveways will have some slope in it - use a jack if need be to get the car level.
    and 3 Dangerous non ABS VN's
    VS
    Feb 2011
    Newcastle
    Even though it started with 0 litres and read 66 after i only put 50 litres in?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by cattz View Post
    It may be set to 80 lts on the trip computer switch at the bottom of the cluster.
    VS
    Feb 2011
    Newcastle
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    If you have a V6 the standard capacity for a sedan is 63 litres, for a V8 and for Statesman/Caprice the standard tank is 75 litres. The larger tank was available as an option on the V6 but only for sedans.
    Check the attachment below re calibrations.
    Attached Thumbnails Attached Thumbnails VS Calais/Statesman dash calibration issue???-tripcal001.jpg
  1. Staesman dash Calibration info needed
    By Statey777 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2010, 06:19 PM
  2. Dash Calibration
    By Chris92 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-07-2010, 09:18 PM
  3. VZ Speedo calibration issue
    By HSVenforcer in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-01-2010, 02:07 PM
  4. vt dash calibration needed
    By dcjacko in forum Electrical Wiring / Questions
    Last Post: 08-10-2009, 07:27 PM
  5. Statesman Dash n Centre Console into Calais
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2006, 04:33 PM
