Results 1 to 2 of 2
Thread: VR 5L sump and cross member removal (HELP)
    VR 5.0L Caprice
    Mar 2011
    Broken hill
    Default VR 5L sump and cross member removal (HELP)
    Hi guys, I am currently in need of an oil sump gasket replacement.. Can anyone point me in the right direction as to which bolts need to be undone on the cross member and p/s rack ?? (pics would be great). I am also aware that I need to lift the engine with a crane to get the sump off..Any help would be appreciated..
    vr ss
    Jun 2005
    i did mine the dodgy way i made a brace that sits over the strut towers then a ratchet strap to support the motor to the brace then dropped the k frame there is 4 bolts holding the k frame to the rails 2 bolts that hold the power steering rack to the k frame there is a couple other bolts ull have to undo and ull have to take the shroud off thats under the converter ummmmmmmmmmm and its a pain in the ass job but MUCH cheaper then a workshop i did my timing cover at same time when i did mine a while ago when i had the 304
    hmmmmmmmmmm
  1. vs v8 manual getrag cross member
    By VsMatt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2011, 03:15 AM
  2. CAE gearbox cross member
    By SLE-883 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-11-2010, 12:25 PM
  3. ecu req for auto to man conversion and g box cross member
    By clubby_you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2009, 04:56 PM
  4. FS:(SYD) VP V8 Front cross member and VL non power rack
    By RACE5L in forum Parts And Other Items For Sale
    Last Post: 04-11-2008, 11:07 PM
