Results 1 to 3 of 3
Thread: Drives fine but when turn it off after short drive ?
    vr commodore
    Sep 2011
    windsor
    Default Drives fine but when turn it off after short drive ?
    HI, the last couple times i have driven my commodore it starts up fine but after i drive it for short amount of time i turn it off and try start it again, it starts depending on how long i have driven it but when push down the throttle it stalls! the air intake taco goes right down and the car stalls. I had a problem recently with the thermo fan and put another relay in and it seemed to be working but i think this has something do with it cause its seems to be running really hot even after a short 15 minute drive or even less?
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    check for error codes, but could be the cas(Crank Angle Sensor), try pouring some water over the cas when hot and see if it starts straight away, it's on the right side of the ballancer.
    Fault code procedure here
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    once it starts do you see any black smoke out the exhaust or smells rich
  1. VT idle's fine soon as you rev it / drive it missfires and wants to stall
    By chrizza132 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2011, 06:55 PM
  2. Car drives fine in LPG but is really sluggish on fuel...
    By deXtrous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2010, 10:11 AM
  3. idle fine,drive like shit!!
    By a9xtorana in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-12-2010, 06:45 PM
  4. Stalls on Idiol but drives fine????
    By aussi3bl0k3 in forum Tuning
    Last Post: 21-07-2009, 08:42 PM
  5. VE Full Map/ Turn by Turn SatNav question
    By Boeing737 in forum VE Holden Commodore (2006 - ?)
    Last Post: 10-05-2007, 10:53 AM
