Results 1 to 17 of 17
Like Tree3Likes
  • 3 Post By Morton
Thread: Engines
    1997 VS Berlina
    Apr 2011
    South Sydney
    Default Engines
    Hey all,
    just wondering how different the VE commodore engine is to my VS (6 cylinder).
    I'm thinking of putting a VE or VZ engine in my VS but not sure on the VE.
    The VZ is basically the same as my VS correct?
    Chris
    Morton's Avatar
    Fairstar the Funship
    May 2006
    They share nothing in common.
    The Ecotec is a OHV (pushrod) 3.8 litre engine.
    The Alloytech is a DOHC 3.6 litre nightmare.
    The 1972 HQ Kingswood
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Both were manufactured by HEC. That is all they have in common.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    1997 VS Berlina
    Apr 2011
    South Sydney
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    lol, emotec.
    if you want to change the engine the vy one will prob be the way to go though.
    theirs not much point tho.. unless your engine is fecked
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    1997 VS Berlina
    Apr 2011
    South Sydney
    yeah my engine is starting to struggle and i was going to change the gearbox soon so i just thought maybe a whole new setup
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Ecotec is a hardier more simple engine less prone to problems then the later Alloytec, you better off keeping it an ecotec.
    1997 VS Berlina
    Apr 2011
    South Sydney
    ok so a VY seems to be the way to go
    does it line up with the same engine mounts and etc?
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    One would assume you would use the engine mounts and exhaust manifold and inlet manifold and plenum chamber and TB from the VS.
    Plus I think there is a pulley that needs to be changed as the air con compressor is not the same type as used in the VS.
    1997 VS Berlina
    Apr 2011
    South Sydney
    ok cheers and it would also be with a new manual gearbox whereas my current one is auto i would have to get the pedal box etc for the vs right
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by CJ - 1995 View Post
    Yes and a ECU to suit the manual box.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Don't want to be a downer on your idea but if you don't know the differences between the VE and VS mechanics then maybe your better off selling your car and just buying a factory manual VS as there is a fare bit involved in engine / gearbox, swaps / conversions.
    Good luck.
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Quote Originally Posted by pjdm1980 View Post
    Good luck.
    From what I understand he is now on the lines of a VY engine.
  15. #15
    1997 VS Berlina
    Apr 2011
    South Sydney
    haha yeah i really only know the basics of engines and etc but i wont be doin this by myself i know people that work with cars and have personally had commodores i just want to make the decision on what to do before i go talk to them
  16. #16
    Morton's Avatar
    May 2006
    Beware, VY engines have the sumps that are a PAIN to work on. Take it from a bloke who's changed a few in-car >_>
  17. #17
    1997 VS Berlina
    Apr 2011
    South Sydney
    yeah but it still is probably the best way to go with a VY
  1. Engines
    By makdaddz in forum General
    Last Post: 23-04-2011, 09:10 PM
  2. vn s1 and s2 engines
    By noyzv8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2010, 09:39 PM
  3. LG2 Engines
    By spacman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2010, 01:23 AM
  4. engines
    By shonky12 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2007, 08:23 AM
  5. VR engines??
    By comblydore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-09-2005, 12:33 PM
