Results 1 to 6 of 6
Thread: vs v6 strange issue
    VK custom
    Jul 2006
    Default vs v6 strange issue
    heyas allright im working on a car atm with an odd problem i have fuel at the rails fuel pump is good seem to have spark and yet i cannot get injector pulse i have a VS myself that was stacked. (long story) have taken the ecu and bcm and keyhead over and still the same issue any advice?
    been trying to figure out exactly what sensor/s could be the issue so my thoughts are
    crank angle sensor? anyone got pics guide to the change?
    cam sensor same thing anyone have some pics diagram or guide?
    or the DFI module what would everyone think be the most likely problem?
    any and all help is appreciated im not the first to work on this vehicle and one previous person ive been told squirted some fuel into the intake and the engine fired up so that kinda backs up what i surmised just have to figure out what the actual issue is
    forgot to mention its coming up code 12 all good so its not logging any faults
    VS
    Jul 2010
    Sunshine Coast, Queensland
    Should flash 12 up 3 times, then if any others come up well there you go. Injector wiring or the injectors themselves ####ed?
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    dfi moduel will cause your fault i would try this it is the easiest to replace
    VK custom
    Jul 2006
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like the immobiliser is still on - does the flashing red light below the radio go out when ignition is on?
    VK custom
    Jul 2006
    Default asumption is the mother of all ?
    well ill note here im not the person who changed the fuel pump and still couldnt get the car running and ill even state i dont know the person BUT i will say the person is a tool after all the testing and all the frustration it helps if the fuel pump lines are actually on the correct outlet or inlet as the case may be i pulled the reg from the rail to see what the hell was going on and in the end yeah fuel pump changed to backwards BAH
    got it running atleast in the end
    thanks all for the help appreciate it
    long story not going into the rest of it and yes i changed the dfi and when it still wouldnt start i started at the back of the car and went from there.
  1. VX Calais strange issue
    By stockyvrcalais in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2010, 05:20 PM
  2. Strange camber issue
    By stocky in forum General
    Last Post: 02-06-2010, 10:54 PM
  3. strange roadworthy issue
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-04-2009, 03:42 AM
  4. VX Calais strange overheating issue
    By marsh_e79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2009, 02:33 PM
  5. Strange rear speaker issue.
    By VNCalais98K in forum Car Audio
    Last Post: 31-01-2007, 11:53 PM
