Results 1 to 13 of 13
Thread: VS Commodore questions-door card removal and rear parcel shelf removal.
    1996 Holden VS Commodore S
    Sep 2011
    Far North Coast, NSW.
    Default VS Commodore questions-door card removal and rear parcel shelf removal.
    Hi all,
    I recently got a 1996 VS Series II Holden Commodore S, which is an excellent car bar one minor fault which is that 3 of the 4 speakers for the stereo don't work. I've tried adjusting the balance etc but no matter what I do the front right hand and both speakers simply do not work, so I've decided to have a look at it myself so I can try and see what's wrong with it. I tried removing the door card today but I didn't seem to be able to get it off, and likewise, I haven't tried removing the rear parcel shelf. Also if I can't get the speakers working, would anybody by any chance have a set of stock speakers they'd be willing to part with cheaply?
    The windows are manual and it's the drivers side with the electric mirror controls if that makes any difference.
    VS Berlina/ KJ Verada
    Sep 2006
    Where are you getting stuck on the door trim?
    To get the parcel shelf out you have to take out the back seat. It's been a while since I had the stock speakers, can you access them if you just take off the speaker grills?
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
    Sep 2011
    There seems to be something in the middle, towards the top that won't come out. I think I got all the screws around the air vents and the 2 behind the clip off cover just near the mirror control but I still can't get it off.
    I've heard that in order to get to the speakers you need to take the parcel shelf out-I'll try getting the speaker grills off and seeing if that helps [my last car needed to take the whole shelf out, either that or just break the clips holding the grills in but this is too nice a car to just "break"]
    Sep 2006
    From memory the grills are pretty easy to pop out and put back, just pop them off and have a look around, you may be able to see if the connections have come loose or something.
    If you've definately taken all the screws out just give it a good yank and it should come off. There is a few little clip things down the side and from memory one along the top, which is what might be holding you back.
    95 VS Berlina
    Sep 2011
    The clip along the top would probably be it-how hard is it to unclip it, or is it just a case of a good yank?
    VS Executive S2
    Jun 2011
    take off the bottom seat then u get a 10mm and undo one bolt for each door side seats, push them up then move the middle down theres 3 screw type things pop them out with a flat head and there u go pretty simple
    JustDylan is offline Banned
    VN Berlina
    May 2010
    Dunno about vs but on the vt there is a "U" shaped clip under the winder that can be an absolute prick to get out.
    Sep 2006
    VS Commodore questions-door card removal and rear parcel shelf removal.-trim.jpgThey look like this. Just pull the trim off. The clip may come unstuck from the trim but it can go back in.
    95 VS Berlina
    Sep 2006
    Quote Originally Posted by JustDylan View Post
    Agreed. For my VB/C/L
    I found the ignition key was the perfect tool fo removing that winder clip!
    95 VS Berlina
    Sep 2011
    I only got around to removing the rear speakers today and I can confirm they can be accessed without removing the entire rear parcel shelf. Much better than my last car...
    I'll get my brother to help me get the door card off tomorrow, thank god for a teachers strike!
    Thanks for all your assistance though, it's much appreciated.
    Sep 2006
    VS s-pac Ute
    Jun 2011
    Wollongong
    Quote Originally Posted by AlexVSII View Post
    Hi all,
    He mate its a bit late now but if you still havnt managed to get the door trim off you need to take the window winder off and on the lock for the door pull it up and there should be a red bit/clip on it, the little red panel comes out and then you should be able to get it off unlike my dad that broke my lock.
    ...1995 VS S-pac Ute...
    Sep 2011
    Yeah, I got the door cards off... had to sacrifice a pair of tweezers to get the clip thingy out but who needs to know... New speakers and head unit is all installed and I must say for $150 worth of stuff it sounds pretty darn good.
    Cheers anyway for the help though...
  1. VN? - VR+VS Rear Parcel Shelf Removal (+photos 56k warning)
    By Patrio7 in forum Holden Commodore How-To's
    Last Post: 02-01-2012, 05:13 PM
  2. VL Door Card Removal
    By 87RB30VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-04-2011, 01:23 PM
  3. VS Parcel Shelf Removal
    By LUSTED in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2009, 01:57 PM
  4. VN Parcel Shelf removal
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-02-2006, 07:30 PM
  5. Parcel shelf removal in a vt
    By Steven M in forum Car Audio
    Last Post: 23-09-2005, 02:45 PM
