Results 1 to 4 of 4
Thread: vs automatic with no gears unless selected with shifter
    vl
    Apr 2011
    brisbane
    Default vs automatic with no gears unless selected with shifter
    HI there, im trying to help someone out with a vs v6, there automatic wont shift gear unless manually selected! they said they have changed ecus and all fuses are fine, has anyone come across this problem of have a auto wiring diagram?? Cheers
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Number 17 of 4L60E common problems & failures:
    No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. Remove & Repair transmission. Try not to run or drive the car or further damage could result.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try running the error codes: Checking error codes VR/VS (Revised)
    Could be the throttle position sensor (TPS) buggered and telling the ECU that the throttle is closed all the time or the Vehicle Speed Sensor (VSS) buggered and telling the ECU the car is stationary all the time. There are tests for these sensors in the Gregorys manual.
    If car drives OK manually and has reverse it should not be the sun gear or sprag broken.
    vl
    Apr 2011
    brisbane
    cheers for the info, was thinking vvs. but wont know till i look at the car.
  1. [VT-VX] Install a VZ SS Automatic shifter into VT/VX (working Button)
    By JohnyRock in forum Holden Commodore How-To's
    Last Post: 28-04-2012, 02:47 PM
  2. automatic shifter knob?
    By muzz.tek in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2010, 05:20 PM
  3. Shortening vy-vz automatic shifter
    By 2Com in forum General
    Last Post: 07-02-2010, 12:41 PM
  4. vl commodore automatic gear shifter top LOOSE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    By Shayski in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-12-2009, 03:25 PM
  5. WTB: Holden VY/VZ SS automatic Leather Gear Shifter
    By SIXAPPEAL in forum Swap / Wanted to Buy / Trade
    Last Post: 14-01-2006, 12:42 AM
