Results 1 to 5 of 5
Thread: help with vs ss
    97 vs ss
    Aug 2011
    new zealand
    Default help with vs ss
    hi all new to the site ive got a 97 vs ss and im having trouble with my battery light and air bag light intermitently comes on and off has anyone else come across this
    VS SS
    Aug 2010
    ACT
    Welcome, battery light may be voltage regulator on the back of the alternator, air bag light intermittently could possibly be a loose connection but you'll have to take it to a shop with the comp interface to get the light turned off.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    +1 for voltage regulator. Get this replaced first and see if this also solves your airbag problem. Voltage regulator is cheap and easy to replace. Just make sure you disconnect the battery earth terminal first before you try and replace it.
    97 vs ss
    Aug 2011
    new zealand
    hi and thanks guys thats what i was thinking but need a second opinion cheers
    97 vs ss
    Aug 2011
    new zealand
    thanks guys it was the regulator all good now yippee
