Results 1 to 8 of 8
Thread: Ignition Barrel Replaced Engine Will Not Start
    VZ Executive Wagon 2006 & VR Executive Sedan 1993
    May 2004
    Australia Victoria Geelong
    Default Ignition Barrel Replaced Engine Will Not Start
    Hi Guys,
    I installed a new ignition barrel today all went well until I tested it all goes good but the engine will not start the key reader was also replaced with a new one from Holden.
    What's gone wrong ???
    I get all the lights but no start.
    VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
    VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
    VS
    Jul 2010
    Sunshine Coast, Queensland
    May 2004
    Quote Originally Posted by seq4x4 View Post
    Did you get the head programed?
    Head programed ? Can I do that myself ?
    I only replaced the ignition barrel & key reader why would you need to have the key head programed ???
    Vu v8 ute
    Sep 2011
    Act
    Because it's linked to your computer you need to have the same key head as your old one but the shiney metal thing is all that needs to be replaced with the barrel.
    Cheers Brenton
    May 2004
    Quote Originally Posted by Brenty88 View Post
    Cheers Brenton
    I have not replaced the key head only the key blade so I am using the original key head so why won't it start then. ?
    vs commodore
    Oct 2009
    Tamworth NSW
    The only time you will need to have a new ignition keyfob programmed is when the BCM is replaced with a new one, the BCM and keyfob have to have matching security codes before the BCM will allow the immobiliser to disarm. If a second hand BCM is fitted,the BCM and keyfob must come from the same car so they match eachother. Just changing the key reader wont effect the BCM or the ignition keyfob,as the reader only does just that,it reads the fob for the BCM,then the BCM decides if the key is the proper one or not to allow the car to start.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Is the metal ball part of the key head touching the metal ring on the key reader? And is the key reader plugged in?
    You should have had the barrel cylinder coded to your old key blade, now the ignition key and door key are different.
    MY RIDE
    May 2004
    Quote Originally Posted by accentstencil View Post
    That was the problem the metal ring was not touching the key as it was stuck I have now unstuck it and the car starts phewww.
    Thanks for your help guys.
  1. VS ignition barrel broken. Need to start her.
    By moondog450 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-04-2012, 10:59 AM
  2. Replaced entire ignition system, still cant start on LPG
    By HyperThinker in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2011, 11:55 AM
  3. VS Ignition Barrel
    By seangell in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2010, 06:07 AM
  4. Ignition Barrel
    By commodore nut!! in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-05-2010, 12:35 PM
  5. Ignition Barrel
    By StillDreaming in forum General
    Last Post: 24-09-2007, 04:25 PM
