Results 1 to 16 of 16
Thread: RV 94 Wont start Help
    RV 94
    Sep 2011
    Default RV 94 Wont start Help
    Hi my 94 VR wont start I have linked a IMG_0348.MOV - YouTube">IMG_0348.MOV - YouTube" type="application/x-shockwave-flash" width="425" height="350"> to it.
    '97 VS Commodore Wagon
    Jul 2011
    Although I haven't watched it, I did find it and thought I would link it for you, I've tried to use the Youtube button and never worked, so here's a link.
    HERE
    I'll edit my post once I've watched it and give you my opinion on it.
    Edit: Okay, watched it and I've got no damn clue, could many various things, maybe starter motor or crank angle sensor.
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    vs commdore 1995
    Sep 2011
    adelaide
    run a jump lead from you batt (-)to your motor cause my vr wagon did the same thing its might be the earth lead
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like a flat battery - check by turning your headlights on - if yellow then it's a dead battery.
    RV 94
    Sep 2011
    hi thanks for the info. it was a bad battery. but there is another problem with it. I have got a new video of it. hope the link works. thanks
    IMG 0350 - YouTube
    IMG 0350 - YouTube
    304runner's Avatar
    304runner is online now ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    The battery is still flat... Its just holding a little bit more charge then in the first vid... Replace the Battery and your problem will be fixed.
    Don't rely on this battery to be jumped and to hold charge....
    After all, the alternator might be bad....
    So borrow a mates battery and chuck it in and give it a turn over... If it starts (which it will) have a look at the dash for the battery light.. If its lit u then you will need to replace the regulator in the alternator or the entire alternator itself....
    If there isn't a battery light on the your up for a new battery..
    James39's Avatar
    Jul 2009
    Newcastle NSW
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Yep as above, I'd say your alternator has seized up have seen a couple of VS's do it as well.
    VR S Ute Manual
    Dec 2005
    Central Coast
    Try soaking the alternator in WD-40 or silicon spray and see if you can get a socket on the alternator pulley and try to get it spinning again?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I'd just take off the serpent belt and fire it up, see how that goes?
    RV 94
    Sep 2011
    thanks for the info. I have but a new battery in the car and it still did not work so am going to try the alternator.
    RV 94
    Sep 2011
    if I was to put a new and fully charge battery in the car do you think that would start the car?
    VR S Ute Manual
    Dec 2005
    Central Coast
    Yeah but if the alternator is shot the battery won't recharge and will only last a few days before it dies...
  15. #15
    RV 94
    Sep 2011
    ok I but a new battery in the car and it just dose the same think. It wont start. so can it still be the alternator?
  16. #16
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Id be taking the belt right off the car and then turning the car over. By removing the belt it wont have tension on the alternator that appears to be seized.
    There is a pulley (the one that is moving left to right in your video) you place a spanner on and pull it down to the left (no to undo the bolt just to swing the belt tensioner) it loosens the tension of the belt making it possible to remove it.
    If the car starts and runs fine then you know yo gotta replace the alternator or a water pump maybe.. Either one, I doubt both....
  1. New Key now car wont start and cuts out when km's on cluster start flashing :(
    By rowiejoan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2011, 10:44 PM
  2. vs calais wont start unless i kit unlock before i start
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2011, 06:40 PM
  3. VP v6 wont start
    By lufkin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2010, 03:17 PM
  4. VL wont start yet again..
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-12-2009, 11:56 AM
  5. vc - wont start
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2006, 04:35 PM
