that looks like the manifold vacuum hose to the fuel regulator.
muttley383
Any idea how i get in behind there to find out where the connection on the manifold is?
Get hold of a small mirror and a torch.
So its to the Fuel Pressure Regulator Connector? And is that straight down behind the distributor or at the front near the radiator?
Thanks for the help
the hose is travels down the middle of the manifold to the connection behind the throttle body.
Look at the .pdf I supplied in the above post.
muttley383
yeah i did, still a bit confused, so it goes in and under the back of the manifold (dustributor side) and goes all the way to the front of the manifold through it somehow? To the connector on the radiator side?
As in the rear of the manifold is closest to the cabin and the front of the manifold closest to the nose of the car?
