G'day i have taken off my fan blade and putting in au thermo fans was wondering where do i get the round plate that bolts on to the water pump pulley where the fans used to be, i had one on another car before but can't remember where i got it, any help would be appreciated.
From the V8 water pump you normally have a water pump hub, a water pump pulley (the one the belt runs in) and then the fan hub and blade. If you've taken off the fan hub and blade to install thermos, then you only need the water pump hub and the water pump pulley. However, you will need a set of shorter bolts. I presume the "round plate" you refer to is the water pump pulley.
Try that -
How To Install AU Thermo Fans Into VN-VS V8
thanks guy's
Also was wondering what size fuse to run for au twin thermo fans as well thanks
is there anything written on the back of the fan motors? Rated Amps or Max Amps?
My setup uses two mini relays and two 30amp fuses. Note that fuse holder on top right is for stereo.
