Results 1 to 4 of 4
Thread: 4hd or 4hdd
    94' V6 VR UTE 4SP AUTO
    Sep 2011
    Drouin (VIC)
    Default 4hd or 4hdd
    Hi Guys
    I've got a June94 3.8 vr ute an my tranny crapped it's self on the side of the freeway the other day and am after another one. From what i hear weather it's true or not, apparentlly in Sep/Oct thereabouts in 1994 the vr went to a vs tranny, the main difference being the solenoids, one solenoid used for overdrive and lock-up on a 13pin plug and the other had 2 solenoids for the same job with a 14pin plug, the sticker on my tranny has come so i'm not sure what it is. Apparentlly you can swap one way but not the other.
    Any help would be appreciated.
    James
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think it's 12 pins for the VR and 13 pins for the VS.....I also have heard that around VR/S changeover time, they fitted the 13 pins to the VR....but not whether to believe that.
    So, to be sure, if you have 12 pins, only replace with a 12 pin trans.
    VR S Ute Manual
    Dec 2005
    Central Coast
    The model number is stamped on the back drivers side of the 4HDD just above the oil pan...
    I replaced my 4HDD with a 5HDD, the 5HDD gearbox worked but was missing the 13th wiring connector on my 93 VR... The box worked O.K but always displayed an Engine warning light and it didn't lock up at highway speeds... I got the shits with the auto's and converted it to manual
    Sep 2011
    Drouin (VIC)
    ok thanks guys
  1. Can I put a 4hdd8 in a VR with a 4hdd?
    By Damobirch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2011, 05:34 PM
  2. [NSW] wtb vr auto 4hdd
    By moff_man in forum Swap / Wanted to Buy / Trade
    Last Post: 03-07-2010, 09:22 PM
  3. Can a 4HDD be put in place of a 6HDD in a 96 VS
    By matstar1000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2010, 09:03 PM
  4. 4HDD auto Problems
    By VR comme in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2009, 12:40 AM
  5. 4HDD Auto
    By Chris E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2009, 01:01 PM
