Results 1 to 15 of 15
Thread: Spark Plug Leads
    vs ute and vt berlina
    Aug 2011
    country, western australia
    Default Spark Plug Leads
    Hi guys, upgrading ignition leads on VS Ute. Is there any point in upgrading to High Tension leads or not? Thanks
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Hye Mate.
    I Have found no difference between OEM leads (what i use) to say Top Gun and Eagle HT Leads. So long as they are with in the correct resistance range.
    You might find a difference if you have a high performance engine, But on stock ecotecs i found no difference
    '97 VS Commodore Wagon
    Jul 2011
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above, standard is fine.
    BTW 'High Tension leads' is another term for ignition leads.
    Aug 2011
    vs v6 wagon
    Apr 2010
    LPG installers have told me to use the latest OEM genuine holden leads that are supplied for your vehicle. Other brands can cause misfire.
    I use holden leads anyway and run it on premium unleaded.
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    I tried aftermarket but had too many problems - bought oem & never looked back no difference in price really
    VR v6
    Jan 2011
    perth
    Leads are leads...not sure how you guys could be having problems with aftermarket ones. I bought a set of Champion leads when my old ones crapped out and so far they've been just fine
    commodore
    Aug 2009
    australia
    i always use aftermarket leads and have never had a problem with them, as above leads are leads.
    strgas's Avatar
    Oct 2009
    leads are different from OEM to aftermarket in construction in the materials used where it be copper lead ends or stainless steel ends , maybe of a low resistance or suppressed for less radio noise , high temp silicone boots with or without heat shields , thickness of leads can range from 6.5 mm to 12.0 mm , have a wire spiral core for low resistance or a standard carbon core , after many years of converting cars to lpg i have heard alot of claims and reasons as to why others leads arent as good as the next guys or OEM leads at the end of the day it comes down to lack of maintenance and care of the leads , seen to many leads rub thru on engine components or even just left hanging and rubbing on the strut tower , burnt thru against the exhaust pipping , rough handling of the leads , spark plugs not changed often enough poor tune settings causing lean burn and over working the spark plug leads .
    vs commodore
    Oct 2009
    Tamworth NSW
    Plug leads always seem to be the one thing a lot of people seem to neglect. These days, with the high voltages used in the EFI ignition systems, plug leads wear out quickly when compared to the old coil and points ignition systems where you could easily get a set of leads to last for years.
    I replace mine every 12 months or thereabouts, I just use normal bosch brand replacement leads, Ive tried a few different "performance" leads over the years and Ive never found any real noticable difference between any of them.
    Nov 2009
    Bundaberg
    I tried the Bosch race ones & they where crap - Repco leads are great for a general ignition lead - I had a workshop & sold them for years without any problems at all- resistance is probably a bit high.
  15. #15
    VS Executive S2
    Aug 2010
    melb
    Hey guys, do you think a dodgy new lead may be cause of a slight lumpy idle?
  1. spark Plug leads
    By paulbenning in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 09:04 PM
  2. spark plug leads for VT
    By smiley235 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-12-2006, 10:29 PM
  3. Which Spark Plug Leads For VT V6
    By Swift Jimmy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2006, 08:10 AM
  4. spark plug leads
    By AndyVKSSA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 11:26 AM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
